BPD bypass filter question- - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-04-2013, 12:19 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Question for those that have the BULLET PROOF DIESEL bypass oil filter with the amsoil upgrade. The little reducer plug that you screw on so you can run the AMSOIL filter, I was considering maybe locktiteing this plug on. Just seems that if this little plug ever came out with the filter that this could be a PIA.
What did you guys do?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 4 Old 08-04-2013, 01:20 PM
portcity_gt's Avatar
Quoted: 1456 Post(s)
I put loctite on my adapter. Its good insurance and wont hurt a thing.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 4 Old 08-04-2013, 02:52 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Locktite won't hurt. If you tighten down the adapter really good, then it shouldn't come off when removing the used filter. Your only suppose to hand tighten the filter onto a filter head. When a used filter gets stuck onto a filter head, it's usually the rubber seal that makes the used filter a PITA to get off.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 4 Old 08-04-2013, 03:10 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
right on thanks for the advice guys. Looks like Im gonna lock-tite it just for happy thoughts.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
