Glowshift Gauge and Fuel Help!! - Ford Powerstroke Diesel Forum
post #1 of 27 Old 08-03-2013, 08:42 AM Thread Starter
A little backstory, I had about two months ago truck was running rough. Took it to stealership and was told #1 injector was bad. Replaced myself from member on here with Ford reman. Only lasted 750 miles and truck just died. Had it towed to Bulletproof diesel shop local to me and was told #1 and #2 were bad? $1300 and back in business again.
This week installed glowshift 3 in 1 gauge setup and accidentally switched the boost and fuel pressure gauge first before noticing that I was an idiot and put them in the right spot. Problems lie in that bosst gauge is only reading half of the boost that it should via my dashboss and fuel pressure is 20 and lower the whole time?
Can the truck even run on that low fuel pressure? and it drives fine. I installed the strictly diesel line and sending unit behind the battery. Or are the sending units shot you think because I ran the truck with them in the wrong spot.
jdilliplane1 is offline
post #2 of 27 Old 08-03-2013, 07:49 PM
20 is awful, you would know it if your truck had 20lbs of fuel pressure. I'd bet on the gauges themselves or the sending unit. Glowshifts are nicknamed "glowchit" for a reason.
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
post #3 of 27 Old 08-03-2013, 07:50 PM
Did you bleed any air from the adapter? Also the sending unit should be lower than the fuel bowl assembly so the air will bleed itself out when the truck is shut down.
Powermax
XDP Coolant Filter
post #4 of 27 Old 08-04-2013, 05:29 AM Thread Starter
I did bleed air out of the assembly, can u screw a adapter to the strictly diesel shrader valve? It also is lower than the bowl.
post #5 of 27 Old 08-04-2013, 05:31 AM Thread Starter
I'm looking at getting a regular gauge that will go to the shrader. I have the blue spring installed some time ago but may be thinking the pump is suspect due to replacing them recently
post #6 of 27 Old 08-05-2013, 01:50 PM Thread Starter
Ok I hooked up both a mechanical gauge and the electrical one, they're both reading like nine lbs but the truck runs ok. I replaced te fuel pump today with one from autozone and still no change? I'm thinking debris somewhere but I wanna make sure before I pull the tank!!
post #7 of 27 Old 08-05-2013, 07:27 PM
9 psi? I don't see how that could be right lol. The truck should be at 60 or so at idle and not drop below 45 at WOT. I don't think it would even run on 9psi.
Powermax
XDP Coolant Filter
post #8 of 27 Old 08-06-2013, 04:33 AM
Therabbittree's Avatar
Do you have a mech oil pressure gauage?, you can retest it on you schrader valve etc.. 9psi is crazy. What did Bulletproof Diesel say?, what readings did they get? if you really have 9spi.. I'd bet all your injectors won't last long.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #9 of 27 Old 08-06-2013, 06:39 AM Thread Starter
Yea I have a mechanical fuel gauge hooked up to where the shrader was on the strictly diesel line. I don't see how it can be that low, the diesel place said that the pressure was fine when they changed the injectors. I'm at a loss as where to look next? Couldn't imagine fuel pump would be bad out of the box
post #10 of 27 Old 08-06-2013, 07:09 AM Thread Starter
I'm at a loss, I checked the lines with no problems, still reading low. Fuel bowl fills up in a few seconds like it should? At this point I really don't wanna replace the pump again but it looks like the next logical thing. Is there a way to see if the blue spring update is working correctly? I've driven about 800 miles with it reading this low so I'm at a loss since its not affecting drivability.
