Rear Axles... Lockers... Help! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-30-2013, 01:26 PM Thread Starter
ZIKA's Avatar
I touched on this before but I broke a left rear shaft and replaced it. Now, my detroit locker will no longer unlock. I spoke with Eaton tech support and he said that I stripped off the teeth from the shock of the broken shaft which will apply un equal load and make it lock up. He said it was pretty common. I havent open it back up because I have to drive it still. I need to clean my stock carrier and get it ready to go back in there but its all rusted from sitting for 5 years or so.
The AAM1150's are huge money and parts are huge money like ring and pinion and lockers. The dana 80 is cheap but they dont offer 4.56 gears for it and I am not sure about the width. I think that a cab and chassis F350 Dana 80 may be my best bet. But then I need to change my front ratio as well and would have to run a 4.30 in both. Any input? Im lost!
I am sick and tired of this rear end...
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #2 of 15 Old 07-31-2013, 03:30 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Ok that was a lot of info real quick lol. You broke a rear inner axle shaft? Dang! How? I have broken my front but not rear! I've twisted two drivelines and not broken a rear inner axle. I've seen the pinion tear off the axle housing on the 10.5, breaking the axle seems strange, but anything and everything breaks. I can buy the theory you screwed up the locker in the works of that event, but that's the first Detroit failure I've heard of. When my front inner axle broke I called all over the major suppliers like 4wheel parts and Randy's ring, and s couple axle builders. Nobody makes hardened 4130 inner axle shafts for these trucks because they don't break often. I replaced my stuff with OEM (i hate cause i always upgrade)and now try not to replicate the event (high speed lockers on hydro steering Baja lol). Your stuck with expensive options if you want to upgrade. Unless your building a competition sled puller I think getting a new locker and inner axle shaft might be your cheapest route if you can avoid a recurrence.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 15 Old 07-31-2013, 06:24 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
You could always have the axles cryo treated for added strength if there aren't better axles available. But I agree with Rob. Put another Detroit and oem axles in and you should be good. Sometimes stuff that shouldn't break does due to variety of reasons.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 15 Old 07-31-2013, 07:21 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Throw a set of rock wells in there lol, fill em with overson shafts and a Detroit, you won't break em ever again. It'd only cost about 10k bucks, oh...and you'd have 6.72 gearing lol. I just got done building a set for a mud bog buddy
Yeah, or do what rob and Mitch said. I'm glad someone mentioned cryo treatment. Some also say vibratory treatment and shot penning adds strength.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #5 of 15 Old 07-31-2013, 07:31 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I thought rockwells came in a 7.17:1??
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #6 of 15 Old 07-31-2013, 12:38 PM
Dirty_Stroke's Avatar
I'm pretty sure you can get the Rockwell with either gear set. Although the standard ratio is 6.72
I would just get another Detriot and stick a factory shaft back in it. I broke a Detriot in the rear of a CJ one time with a 6 cylinder and 35's. Nobody could answer why the Detriot broke. Strange things just happen every once in a while.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #7 of 15 Old 07-31-2013, 07:20 PM Thread Starter
ZIKA's Avatar
Yukon makes chromoly rear shafts for about $600 shipped but I'm just going to run the stock carrier for now until I figure it out. I'm at the point to where it breaks at least once a year and that's with oem u joints. I would really like to do an axle swap.
ZIKA is offline
post #8 of 15 Old 07-31-2013, 07:45 PM
Is your truck a stick shift? I can't believe your tearing that Sterling out so easy with 37's.
post #9 of 15 Old 08-01-2013, 07:36 AM Thread Starter
ZIKA's Avatar
The truck is a stock auto trans. I think what may help and I dont even know if this is possible... have a button to unlock the converter within the last couple feet of a sled pull to give it a little slip. I know the older dodges are able to do it. Other than the rear axle, the truck holds up great with a couple few exceptions.
ZIKA is offline
post #10 of 15 Old 08-01-2013, 09:44 AM
Rick C's Avatar
I'm no sled puller so any thing I might say could be useless info...but. What about a set of F450 axles. Dana 135 in back and a super 60 in the front. I'm not sure that 4.56's are available but 4.30's and 4.88 are. As for a locker carrier for the rear...i'm not sure.
2005 F-450 CC Fontaine Conversion
(It's the heavy GVW one with the Dana 135, 4:88's and bigger brakes)
Link Air Ride Suspension
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 with Eric's tunes
Bullitt Proofed (EGR mod, Remote oil cooler/filter, Water Pump, 7.3 fan clutch conversion)
ScanGaugeII
Odyssey AGM's
High Idle Mod, CCV Mod
ARP studs...Finally
More $$$ to be spent i'm sure!
Rick C is offline
