Need Help!!! Which to buy?!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-29-2013, 11:27 PM Thread Starter
dbrandone's Avatar
I have read through this forum and throughout the Internet and have found pro's and con's for all but want some opinions on which one I should choose.
I will be purchasing one of these set-ups tomorrow but I'm unsure which...
PHP Gryphon FICM Programmer-Love the idea of tuning the FICM and its advantages with throttle response, mpg's and of course power. No EGT Probe or dash kit but 400 bucks
Edge Evolution CS-Love the color screen and tuning options. Like the options for keeping an eye on your truck and customizable features. No egt or dash kit and 500. Maybe 40 bucks cheaper at 459.
(Used) Edge Juice w/ attitude CS-Like everything like the above option but haven't found any additional options other than shift on the fly that separates itself from the evolution cs. This used kit comes with a pillar pod, egt kit and everything else it came with new. 500-550 bucks.... I also have heard bad things about the juice with attitude but don't know it centered around the earlier model.
I'm looking to spend around 500 bucks so any other ideas other than these 3 are appreciated but I'm purchasing tomorrow so any input would help.
Sent from AutoGuide.com App
2005 F-350 Lariat CC SRW LB FX4 - SIlver
Custom 6" Lift w/ Dual Bilsteins, 35/12.50/20 Nitto Trail Grapplers, 20x10 XD Strike Wheels in Matte Black, ARP Headstuds, PHP Gryphon FICM Programmer(Currently using Atlas 80), Volant Intake, 4" Turbo-back Straight Pipe Exhaust w/ 6in Tip, 6000k Retro Solutions 55w HID Kit
dbrandone is offline
post #2 of 5 Old 07-30-2013, 12:16 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Sct programmer. I think the livewire sct which is also a monitor is like 500 or 600 but its everything a programmer and monitor. Don't tune with anything but a sct prodoct they are the best
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 5 Old 07-30-2013, 05:40 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
SCT with custom tunes!!! And a monitor solution!!
What to look for when buying used SCT for 6.0
Write Up: Monitoring the 6.0L PSD.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 5 Old 07-30-2013, 07:48 AM Thread Starter
dbrandone's Avatar
I will eventually buy the SCT x3, but for now want to have gauges but would also like some basic canned tunes for the time being. I mainly want my FICM tuned down the road with a small to moderate ECM tune and thats why I thought a canned tune with a FICM tune down the road might work.
At this point, I've narrowed it down to the PHP FICM Programmer(Evolution Programmer) w/ 4 FICM tunes and Dash Pod for 450 or Edge Evolution CS w/ 5 canned tunes and dash pod for 510.
With the idea that a SCT x3 will be purchased in the future, what are you guys thoughts on these two systems?
post #5 of 5 Old 07-30-2013, 09:21 AM
Powerstroke Techie
Lilpooh's Avatar
You keep referring the the Edge Evolution, which is a programmer and tuner. If your just wanting a monitor, then you want to look at the Edge Insight. The Evolution is "ok", but for the same price or less, you can get the best (more options/tunes) for your 6.0.
If you plan on going with a SCT X3, then it can only run custom tunes. The SCT SF3 holds canned and custom tunes.
The SCT canned tunes aren't bad, but custom tunes are much better.
You need to make a decision on which way you want to go, either a tuner/monitor in one unit, like the SCT Livewire TS.
You can also go with a separate tuner and monitor. The SCT X3 is popular, and only holds custom tunes. The SCT SF3 holds canned and custom tunes. Then use the X3/SF3 with a monitor like Edge Insight CS/CTS, ScangaugeII, DashBoss for iPad/Itouch/iPhone, or Torque for Android based tablet/phone.
Lilpooh is offline
