Noise? Yukon YG F10.5-373-31 High Performance Ring & Pinion - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-28-2013, 12:28 PM Thread Starter
smokersteve's Avatar
Quoted: 20 Post(s)
Has anyone used this in the 10.5? Is there a noticeable amount of noise?
Is their standard Yukon ZG F10.5-373-31 Usa Standard Ring & Pinion the same as OEM?
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #2 of 2 Old 07-28-2013, 01:06 PM
Typically, noise is from the ring being too close to the pinion. This will show itself in insufficient back lash. Regardless of who installed them, the back lash and wear pattern need to be double checked before it gets worse.
I had some used 4.11s in my Mustang, they had been excessively tight for so long, even loosening the back lash wouldn't stop the screaming. I ended up buying new and learning how to do a gear swap.
Karl
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
