Can you bolt on an 03 compressor housing and wheel to an 05+ turbo? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-27-2013, 03:23 PM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
I have several turbos collecting at work and I was wondering if anyone has ever thought about this. I supposed I could easily try it but I wouldn't want to mess anything up.
I've got 2 stock compressor wheels sitting side by side and I was pretty surprised at the difference. I can see the 03 wheel has about a .040" larger inducer. I've heard the 13 blade turbine is more efficient also. Can we have the best of both worlds or did I just describe an 04 turbo?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #2 of 10 Old 07-27-2013, 03:27 PM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Move this thread to performance please
post #3 of 10 Old 07-27-2013, 03:38 PM
sprksonu's Avatar
im sure nate from MTW would have your answer
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #4 of 10 Old 07-27-2013, 04:28 PM
It will have the same power because of the PCM via the MAP and MAF, but it would cost you more MPG
JorgeCanek is offline
post #5 of 10 Old 07-27-2013, 04:43 PM
turbotibbo's Avatar
Subscribing , I also have a few stock turbo laying around
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 10 Old 07-28-2013, 05:43 AM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Nah it won't fit and the gains wouldn't be worth it if it did.
What I decribed is an 2004.25+ turbo. It has the same compressor wheel as the 03 and a 13 blade turbine like the 05+. Why there's so many different turbos I'll never know. I did have an 04 turbo once too but I gave the sucker away.
-Matt
2015 F-250 XLT 6.7L
post #7 of 10 Old 07-28-2013, 06:38 AM
Why it wouldnt fit? Diffrrent bolt pattern?
post #8 of 10 Old 07-28-2013, 08:19 AM Thread Starter
Powerstroke Techie
Quoted: 15 Post(s)
Garage
I am not sure. I will swap covers on my turbos tomorrow if I get a chance. All of my turbos have bolt on compressor housings.
Remember there are actually two different style 03 turbos. One has clamp plates for the compressor housing and the other is the normal looking bolt on style compressor housing. The two 03 housings are not interchangable. Perhaps it is easier just to say that they won't work but I don't know for sure, just what I was told.
-Matt
2015 F-250 XLT 6.7L
post #9 of 10 Old 07-28-2013, 08:33 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 958 Post(s)
Feedback Score: 6 reviews
Moved it for you.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #10 of 10 Old 07-28-2013, 08:36 AM
peixinho's Avatar
Quoted: 207 Post(s)
I just recently put on 06 compressor housing on my 03 turbo... fit just fine. I just had to change out the compressor housing, backing plate, and the compressor wheel.
You might try that.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
