Ball Joints Tie Rods 2005 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-25-2013, 08:47 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Is there a definitive way of checking if the Ball Joints and Tie-Rod ends are bad without dis-assembly?
Also going to check and replace tie rod ends.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 4 Old 07-26-2013, 07:17 AM
kdogg85's Avatar
When my lower drivers side ball joint went bad, it clunked hitting the brakes after about 5 miles of driving. Tried the moving the wheel every direction, used a 2x4 prying up and no movement at all. Tie rods had no slack at all either.
Took a shot in the dark and replaced them. Tore the old ones apart and that one was worn badly, other 3 looked great.
In my case, no sure fire way to check.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #3 of 4 Old 07-26-2013, 06:42 PM
JustinOOO9's Avatar
Quoted: 419 Post(s)
Garage
the old school method is best do it at home, put the front axel on jack-stands and wrap a big pry bar in a towl and pry against your wheels and try and get them to move...
also if your getting a thump sound under your body check your body mounts... had to replace mine at 55k miles the rubber was just all cracked and destroyed, took 45min and now the thump is gone.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #4 of 4 Old 07-27-2013, 08:25 AM
jetjock15's Avatar
Quoted: 110 Post(s)
The pry bar method is how you tell but with the tires on i have not has luck. If you take the tire wheel bearing and pull axle out, so all you see is knuckle and ball joints, then pry between the knuckle and axle tube flange trying to pry the knuckle upward, then it will be aparent if the ball joints are toast or not, if you can pry the knuckle upwards at all. Same works on the trac bar check that lower ball joint too like that. The drag link ( between pitman arm and knuckle) needs to be replaced every so often, just do it if your troubleshooting sloppy steering. The tie road (from knuckle to knuckle) takes much less abuse then the drag link and rarely those wear out (100k replacement) but you can test by prying between knuckle and tie rod same method, with those you can have friend turn wheels back and forth and look for play
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
