Turbo swap - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-25-2013, 07:17 AM Thread Starter
007.3Powerstroke's Avatar
Turbo swap
Ok so i took an 03 turbo and put it on my 04. We did not swap pedestals. so the the question is will the 04 turbo work on the 03 pedastal? we need to get the turbo on so we can trade the truck in.
2004 6.0 Lifted 8 in 37x14.5x20 inch tires
mods so far:
SCT W/ Tunes
4 in from the turbo back.
Glow shift gauges EGT Boost and Trans temp
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
007.3Powerstroke is offline
post #2 of 23 Old 07-25-2013, 07:30 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Depends...is it an early 04 or late? Mine is an early 04 and has all the 03 stuff and only the 03 pedistal will work. The 03/early 04 pedestals are different than the 04+-07 ones.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 23 Old 07-25-2013, 07:32 AM Thread Starter
think mine is an early 04. not 100% sure
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #4 of 23 Old 07-25-2013, 07:34 AM Thread Starter
so if its a late 04 do i have to buy a new pedestal for the 03? we are trying not to spend any cash on this swap. because the 03 is getting traded in. but they want the turbo bolted up and pipes on before the dealer ship will take it. it doesnt run anyways. but they want the turbo on. so is there a way to do that with out spending anything on this? The 03 bolted right up to my 04 with no problem.
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #5 of 23 Old 07-25-2013, 07:37 AM
strokin6L's Avatar
Quoted: 3 Post(s)
If the turbo is from a late build 04 it will not work on an 03 pedestal.
post #6 of 23 Old 07-25-2013, 07:40 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Seeing as the 03 turbo bolted to your 04 truck is obvious that your truck is an early 04 then. So your turbo off the 04 should fit the pedistal on the 03.
post #7 of 23 Old 07-25-2013, 07:44 AM Thread Starter
ok we tried the night we did the swap. but after riding quads all day then started drinking a few and pulling the turbos off. it was like 2 am when we got the 03 on me. so we just left the other truck apart. we are goin to try to get it back on tonight. But i was hoping to hear it should go right back on. i kinda figured it would with the 03 goin on my truck with out any pedestal's being changed.
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #8 of 23 Old 07-25-2013, 08:02 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Correct. If the 03 turbo bolted to the pedestal on your 04... then the turbo off the 04 will bolt to the pedistal on the 03.
post #9 of 23 Old 07-25-2013, 08:16 AM Thread Starter
sweet thanks! we are goin to work on it tonight. hope all goes well
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #10 of 23 Old 07-25-2013, 08:28 AM
Not necessarily, an 03 turbo will bolt up to any of the 6.0 pedestals. I have one on my 06.
WLDHRSE is offline
