68mm KC Turbo Dyno and Video - Ford Powerstroke Diesel Forum
 11Likes
post #1 of 121 Old 07-24-2013, 05:39 PM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
Skip down to bold letter for just dyno results
Well some of you may be following some of my posts but I have ventured into the realm of modding turbos. I have had the goal of getting a turbo for us middle of the road guys. Not looking to break the bank but want to make it into the 500+ hp range without investing mucho $$$$ in mods. It seems like 175cc injectors seem to be to safest bet to guarantee 500+ hp but with some of the turbos out there the trucks can be smokey with really high egts...
I have tried a bunch of different variations which I will not go into here. I have finally found one that meets all my requirements. I am hoping to still tweak the turbo a little bit but I feel that the gains might not be noticed much by the seat of my pants so I am starting to dyno my results. I will use the same parameters for each dyno run so as i change things on the turbo I can compare dyno results. I practiced a lot with my dyno guy and made 10 runs. They were all very close for the last 6 runs so I should be pretty consistent with all my changes.
Also one of my goals were not to chase every bit of hp using a wide variety of mods. I wanted to be able to offer a pretty sure bet of breaking 500+ hp without being super smokey and not having to buy every little supporting mod.
So the only hp mods to my truck: 68mm KC turbo, 175cc/stock nozzles, tuner, exhaust... thats it (well I am supposed to have a 58v ficm but it only reads out 48v and is not supposed to do very much)
Here are the mods that I did not put on the truck because I feel you get very little bang for your buck with these mods compared to others: ficm tune, water/meth kit, aftermarket air intake, ported intake manifold, headers, intake elbow, bigger intercooler, new y-pipes, etc... I am not saying that those don't do anything or that they wasted mods. I was just looking for the cheapest route to hit 500+ hp
AND I MADE MY GOAL
521hp/901tq
here is the dyno graph
I would like to point out a few things on the graph that interest me. I have always wondered the affect of stock nozzles and I think the dyno graph shows it. The torque curve is no very flat and I feel that is because as the rpms go up the stock nozzles have a hard time keeping up with flow. The stock nozzles put out plenty of fuel at low rpms (where most people drive) but when it gets up there the pulse of the injector mixed with the stock nozzles prevent the fuel from keeping up with the demands of the turbo/air.
Also the hp curve is very flat and does not increase as rpms go up, i wonder if that also has something to do with the flow of the nozzles???
I will post some video in the next post.
bgraiders323 likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #2 of 121 Old 07-24-2013, 05:40 PM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
I have a couple of different videos showing how smokey my truck was before and after the new turbo. The first two videos are of the same truck same mods except with 63.5mm turbo. The second two video are with the new 68mm KC turbo. EGTs for these runs went from 1800(63.5 turbo) down to 1550(68mm turbo). Something else you might notice if your sound is on is that the 68mm turbo whistle now... Oh and I have a really hard time keeping traction at anything below 40mph so I have to feather the throttle a little bit.
Before with 63.5mm turbo
Now with the 68mm KC turbo
KC Turbos
post #3 of 121 Old 07-24-2013, 07:26 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Remember, the HP is a derived function of Torque. So as the torque drops off with less fuel and acceleration, the derived HP will not climb as much with RPM. Either way, good numbers.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 121 Old 07-24-2013, 08:44 PM
1fastTRX's Avatar
Was that 63.5mm running a 13 blade turbine or pmax 10 blade? Im guessing 13 since it didn't whistle much
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #5 of 121 Old 07-25-2013, 05:13 AM
I wonder if the ficm tune would help out the stock nozzles?
And do you have a link to the turbo?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #6 of 121 Old 07-25-2013, 06:52 AM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
13 bladeturbine, 11 blade billet comp wheel
KC Turbos
post #7 of 121 Old 07-25-2013, 06:55 AM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
Once i get done deciding on a turbo I might try nozzles and/or a ficm tune to see how it reacts.
There is no link for the turbo. It is just something I have been working on.
KC Turbos
post #8 of 121 Old 07-25-2013, 10:03 AM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
just a thought using the formula to calculate hp from torque.
If I had made 900tq at 3500 rpms then the hp would be 600 (that would be a very flat torque curve) anyone think I can gain 80hp by adding nozzles
well that is according to this website HORSEPOWER TO TORQUE CALCULATOR
Once I get the turbo platform figured out I will put on bigger nozzles and test this theory to see if I can keep 900tq across the rpm band
KC Turbos
post #9 of 121 Old 07-25-2013, 09:33 PM Thread Starter
peixinho's Avatar
Quoted: 173 Post(s)
wow... i thought I would get a few more comments... was hoping for a little constructive criticism or maybe some thoughts on the setup/dyno?
KC Turbos
post #10 of 121 Old 07-25-2013, 09:43 PM
I'm interested in this. It's particularly interesting to me because of just how simple the build really is.
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
