S&B cold air intake - disposable versus reusable. - Ford Powerstroke Diesel Forum
post #1 of 24 Old 07-24-2013, 02:39 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Question for you guys. I'm considering a cold air intake. I like how S&B posts filter data, but open to all brands. Filtering ability is priority one, but I like the idea of flowing more air than the stocker, and everytime I change the stocker I drop way to many Fbombs and swear on Ford's name too many times for making it such a POS to change. Anyway, I did a search of the big powerstroke websites, and everyone recommends the reusable (oilable) filter in the S&B because " the oil will help trap more dirt". I can post the links to the threads, but this was the overwhelming theory. S&Bs website posts the results clearly and it shows the dry disposable filters - filter more dirt. 99.69 versus 99.17 using their effeciancy rating. Anyway, considering ordering this kit with disposable filters because IT FILTERS BETTER. Am I missing something? Thanks.
Is there any other intakes I should consider? Any other kits use disposable paper element filters on the market?
Disposable dry
03-07 Ford Powerstroke 6.0L S&B Filters Cold Air Intake (Dry Disposable Filter)
Reusable need to oil
2003-07 Ford Powerstroke 6.0L S&B Filters Cold Air Intake Kit (Cleanable Filter)
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #2 of 24 Old 07-24-2013, 02:57 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
i bought my S&B with a reusable filter, but once it get filthy im tosssing it for disposable. like you said, the disposable filters better and the flow its only slighty decreased. I personally would take filtering capacity over flow.
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #3 of 24 Old 07-24-2013, 02:59 PM
Raul@Stealth Automotive's Avatar
if you do alot of dunes trips i recommend the dry filter....
we sell both BTW
Raul@Stealth Automotive is offline
post #4 of 24 Old 07-24-2013, 02:59 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yes the dry filter has a "higher" efficiency. However, it has a lower than "over stock" flow percentage. I think this is why you see the over whelming recommendation to get the oil filter. At least that is why I recommend getting it. I personally don't care about a <1% difference in filtering efficiency when there is a 4% difference in flow capacity. Hope this makes sense.
And since I don't drive in dusty environments and don't put that many miles per year on my truck. So I just buy new oil filters so I don't have to mess with it all.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 24 Old 07-24-2013, 03:32 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
we sell both BTW
Pm me a price. If I get one I will use you. Like supporting forum vendors. As of now I just have not decided if I will get one or not. My turbo boosts to 35psi do don't know how it's going to get any more air in there, but I do kinda buy making the turbos life easier helps everything else. I still have a brand new OEM filter in my garage, bought two last time. That makes it even harder to toss out. I dunno. I went to 4wheel jamboree and some diesel Dyno events last couple months and guys did think the intake was an important ingredient with all the other stuff.
post #6 of 24 Old 07-24-2013, 03:58 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Here's a link to the tests, interesting read. Meant to post the link
http://www.sbfilters.com/core/media/...efb28b12b043a5
post #7 of 24 Old 07-24-2013, 04:51 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I'm going to try the kit, Raull hooked me up. Ill post how it does. I would love if it lowered EGTs a tad my making the turbo have to work less hard, but in reality if its a little louder than stock, prettier under hood, and I can change the filter without pulling all the OEM pieces (worst design ever) then ill be happy.
post #8 of 24 Old 07-24-2013, 04:55 PM
Thanks for the order bud... it will go out tomorrow
-Raul
post #9 of 24 Old 09-04-2013, 09:38 AM
badyota82's Avatar
How much is the S&B through you Raul? I'm looking at ordering one as well. Still torn between dry or oiled filter though. Thanks
2006 F250 Lariat CC FX4
Current Mods:
4" MBRP Exhaust
58v FICM w/ performance flash
Blue FPR Spring
SCT w/ tunes from Matt (SRL, 8k Tow, Unlim. Tow)
Edge Insight CTS
1200rpm High Idle
Coolant Filtration System
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
Sold: 1997 F250 PSD 4x2 5 speed
badyota82 is offline
post #10 of 24 Old 09-04-2013, 09:46 AM
william_ace's Avatar
Quoted: 2 Post(s)
I'm curious as well. I also have not decided between oil and disposable, but I think I'm leaning towards the oiled filter that flows more air.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
