Oil cooler options vs. cost - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-24-2013, 08:08 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
I see two potential options:
Bullet Proof Diesel oil cooler which is very expensive
or
New Ford Oil Cooler plus a coolant filter
My thought is that if I can get the coolant to stay clean, the Ford's crappy oil cooler design won't get gummed up, or at least not as quickly. Any experience/advice?
Maybe if I go with option two, I may even install the coolant filter and run for a few months before swapping out the oil cooler so it doesn't get dirty right way.
ynpmoose is offline
post #2 of 26 Old 07-24-2013, 08:44 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Great plan I've spent $1490.00 to date on 3 coolers, 1 Coolant filter System and 3 filters following this plan. Oh and my delta today is 9 deg.
Maybe just maybe i got enough crap out of the system that i just need 1 more oil cooler............
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 26 Old 07-24-2013, 08:50 AM
portcity_gt's Avatar
Quoted: 1284 Post(s)
Several people have had that same plan.....has worked ok for some and failed miserably for others.
But the bpd oil cooler hasnt failed, it proves its self time and time again.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 26 Old 07-24-2013, 11:48 AM
USAFBowman's Avatar
When mine went bad it was the first one I myself had to swap on the truck and I plan on keeping this truck for a long time. Either till it does or when repairing it is not worth it anymore. I went with BPD external oil cooler and never looked back. I would do it again in a heartbeat.
I gotta help my buddy replace his this weekend. Tried to talk him in to going BPD as well. But that's out of his budget right now. Wonder how long this oil cooler will last for him
USAFBowman is offline
post #5 of 26 Old 07-24-2013, 11:55 AM
Snake's Avatar
Quoted: 46 Post(s)
or
Is your oil cooler clogged?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 26 Old 07-24-2013, 02:19 PM
The Silent Service
colo_dually's Avatar
Quoted: 12 Post(s)
or
Most affordable option is to wait to the stage where you need to replace the oil cooler (Deltas in that 14-15* range), and do the job one time with as much efficiency as possible.
-Drain Ford Gold
-Install bypass Coolant Filter
-Run the Restore Plus treatment
-Run the Restore treatment
-Run Distilled Water treatment 5-7 times
-Drain the Oil
-Tear down the truck
-Replace the Oil Cooler
-Solve your EGR Cooler
-Solve your MY issues, if any remain
-Clean the interior of your Intake Manifold
-Put everything back together with fresh filters all around (Coolant, Oil, and Fuel)
-Refill Oil of choice
-Refill Coolant with a quality silicate-free ELC
-Enjoy the truck until those deltas tell you to do so again.
Some owners have great success with the stock oil cooler, I'm at 93K and only needed one cooler replacement to date. Job takes a long time to do correctly, and most shops simply don't understand the 6.0L enough to do it right.
Failures. . . no, but the BPD external cooler, even if you use the newer HD coolers, isn't the 100% solution for every 6.0L out there. In particular, the lower geared trucks, and those that tow heavy. (Check build thread in sig for more details here.)
I really like the newer HD Coolers, and the stock oil filter option. Both will work for a lot of owners, and the build of the parts is second to none. This isn't a shot at BPD, but everyone needs to understand the trade off between the stock oil cooler, and any air-to-oil cooler.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #7 of 26 Old 07-25-2013, 03:51 AM
jetjock15's Avatar
Quoted: 113 Post(s)
To the OP, I can't say enough good about the BPD system. Once you do the oil cooler replacement you'll know why I don't want to do it multiple times. You are weighing the correct decision factors though. Either way I agree a good idea is to add the coolant filter first and let it filter. If you don't have ELC now would be a great time to swap, then let the filter work as long as you can stand, then do the cooler.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 26 Old 07-25-2013, 04:00 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Colo - just to be clear, I know I have posted a lot of data in the past, can be tough to summarize. With my truck on 4.56/37s I've overheated the OEM cooler and the BPD cooler. This was with the BPD standard cooler, it heated less with nearly identical runs, and as an added bonus it didn't take water temps with it. I've posted this before but I firmly believe that towing a "legal" trailer, you cannot overheat the BPD standard cooler, and right at the legal limit you can overheat the OEM cooler. This is on a lifted truck though - more drag more resistance. With stock tires you probably can't overheat either.
post #9 of 26 Old 07-25-2013, 06:01 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
what I plan on doing is waiting until I have a 12-14* delta then doing a coolant flush with restore and restore flush and switch over to Cat EC-1 and then running the truck for a few days until my coolant filter and oil cooler can capture all of the debris (is it bad when I consider my oil cooler as an additional filter lol ) floating around in the system then doing the teardown and oil cooler replacement. After that gets done I would either do another complete flush or would just refill with 50/50 EC-1.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #10 of 26 Old 07-25-2013, 06:41 AM
Chatham036's Avatar
Quoted: 135 Post(s)
Correct me if I am mistaken, but the gear reduction of 4.56 with 37's is still a lower combined gear ratio than the stock setup.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
