Turbo/Injector/Tune Question - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-23-2013, 06:15 AM Thread Starter
paintballbryce's Avatar
I have been looking over the past couple days through all these topics, and I have come to the conclusion that a MTW turbo seems like the way to go.
The question I had was would I be better off getting a bigger turbo, and keeping stock injectors for longer, or just running a stage one and getting 175/stock injectors. I'm looking to get as much power as I can without putting my transmission on the line for right now. Just don't have all the money in the world right now.
Secondly, I'm currently running an ID xtreme street tune right now, just wondering what you have found who has gotten a tune that they have found that seemed like it stood out over most of them.
I appreciate everyones opinion, as I am new to turbo veichles.
Thanks in advance!
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 18 Old 07-23-2013, 06:57 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Get the MTW Stage 1 175 30's from Warren and run Eric's XXX if you're Studded.
If Not
Get a scangauge II monitor your deltas, Blue Spring, Coolant Filter & EGR delete then proceed with the modifications.
If you think you have limited funds now, add power to an engine with known weaknesses.
My .02
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 18 Old 07-23-2013, 07:04 AM Thread Starter
If Not
My .02
Denny
Yea Im studded, anyone second that?
Stock for now
post #4 of 18 Old 07-23-2013, 07:22 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Bigger engine mods and trans reliability comes down to your right foot and prior trans maintenance. So their is no real answer for you.
I seen in your other post, your getting ready to add gauges. If you go with the 3 in 1 glowshift, then you should also get some sort of OBDII monitor. Just watching EGT, boost and FP isn't enough.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 18 Old 07-23-2013, 07:51 AM Thread Starter
Yea that was to come along with all of this. Just not sure what I want to run in my truck as I already have the x3 for tuning, not sure what is good to monitor parameters. Have lots more to read.
Thanks!
Stock for now
post #6 of 18 Old 07-23-2013, 07:54 AM
PGreenSVT's Avatar
I'd suggest an Edge Insight for monitoring. Either the CS or the CTS.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #7 of 18 Old 07-23-2013, 07:55 AM
Powerstroke Techie
Lilpooh's Avatar
Thanks!
This thread is a good start for monitors.
Write Up: Monitoring the 6.0L PSD.
Lilpooh is offline
post #8 of 18 Old 07-23-2013, 08:39 AM Thread Starter
Whats the big difference between the CS and CTS, other then screen size and back up camera capability?
Thanks for all the help!
Stock for now
post #9 of 18 Old 07-23-2013, 09:29 AM
Powerstroke Techie
Lilpooh's Avatar
The CTS is a touchscreen, the CS is not.
Lilpooh is offline
post #10 of 18 Old 07-23-2013, 09:46 AM Thread Starter
Awesome, im leaning towards the cts. I still plan on getting my pod to measure my boost, fuel pressure, and egt!
Stock for now
