Glow shift Fuel Pressure Question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-22-2013, 07:31 PM Thread Starter
paintballbryce's Avatar
Hi guys,
Just had a couple questions, I'm more so illiterate when it comes to gauges and stuff, just wanting to make sure I get it all in one order since shipping to Canada isn't cheap. I was looking at their 3 in 1 gauge with fuel pressure, EGT, and Boost, but I have seen that they have a sensor relocation hose kit, and with that will I still need the 6.0L adapter or no? Is the relocation kit really necessary? Thanks for all the input, as I try and understand all this more! I'm hoping it comes with some instructions or I can find a how to for the install of the egt probe and boost sensor. Is there anything else I will need to run this? I will be getting the colour matched single pod as well, and it seems like there kit comes everything I need.
Thanks again!
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 11 Old 07-22-2013, 09:31 PM
Retired Army
I have their 4-gauge pod and I think if I were to do this over again I wouldn't get their fuel pressure gauge. I'm having issues with it bouncing from high 50s to low 40s / mid 30s but only at about 1500 RPM. I thought this behavior was at all engine speeds but it doesn't appear so now that I'm watching it a little more closely. Also, if I just back off the throttle pressure returns to normal. GlowShift tech support said I had a loose connection but I've checked that and that's not the case. Someone else here had a similar issue and he got a new pressure sensor but GlowShift has not extended that to me (yes I've emailed).
I did purchase the adapter piece from GlowShift and that moved the sensor away from the fuel filter bowl enough to mount it (I removed the test port plug and connected there). I now have the hose from DieselSite (I think) that moves the sensor completely off the engine and onto the body (mine is by the brake master cylinder). I may move the sensor back to the adapter from GlowShift and see if the fluctuating reading goes away.
I like the relocation hose because the sensor is off the engine, there isn't as much interference between the fuel filter bowl / lines / etc. and the sensor, and there is a Schrader valve to bleed air from the line.
I like the adapter because there is less hose between the fuel filter bowl and the sensor, but the sensor is very close to lines / bowl / housing (you'd have to remove the sensor to change to a blue spring for instance) and there is no bleed valve.
I didn't need the adapter when I got the relocation kit from DieselSite.
2004 F250 SRW FX4 Lariat CC LB
Sinister delete, XDP coolant filter, NUC oil bypass, fumoto valves, AFE stock replacement, Riffraff boots, Ultra ELC, CTS and Glowshift gauges, SRL, Wicked Wheel
08 trans pan/filter, 08 diff cover, Racor CCV6000
ranger51r is offline
post #3 of 11 Old 07-23-2013, 09:57 AM
elchaseo's Avatar
Quoted: 8 Post(s)
I got the adapter and had to buy an elbow to move it away from the upper radiator hose. With the adapter alone there is no way it would have worked. Mine also bounces at higher rpms it usually starts when it gets past about 3300 rpm. The other issue I had was the provided o ring for the sender was noticeably smaller than the OEM one on the plug. I just swapped them out and that took care of my small fuel leak.
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #4 of 11 Old 07-23-2013, 10:11 AM Thread Starter
Did you use also use the relocation kit or just the adapter?
Stock for now
post #5 of 11 Old 07-23-2013, 10:20 AM
elchaseo's Avatar
Quoted: 8 Post(s)
The adapter with a 90* elbow I found at Lowe's. If you need me to I'll snap a pic in a bit just let me know. I also used permatex number 2 on the threads. I read that the regular Teflon tape won't hold up to the fuel if it comes in contact. I know there are others that had success with it but the permatex was cheap enough to have handy anyway.
elchaseo is offline
post #6 of 11 Old 07-23-2013, 10:28 AM Thread Starter
Do you think the sesnor relocation would fix the issue for you? or do you think its the gauge itself? I've heard some good and bad about glowshift.
Stock for now
post #7 of 11 Old 07-23-2013, 11:00 AM
elchaseo's Avatar
Quoted: 8 Post(s)
It seems hit or miss with the relocation from what I've read. Hopefully someone with experience using it will chime it as I can't say for sure. For the money they really aren't horrible gauges IMO and they actually look halfway decent.
elchaseo is offline
post #8 of 11 Old 07-23-2013, 12:18 PM Thread Starter
Im hoping someone will clue in, I'm waiting on a response from glowshift, so hopefully I can order it tonight.
Thanks!
Stock for now
post #9 of 11 Old 07-23-2013, 12:20 PM
pcris's Avatar
I installed my fuel psi gauge about 3 months ago and just started experiencing issues with it bouncing high and pegging out at 100. I made sure I installed the sensor and all under the hood very carefully so I don't think it's the problem, and seeing as there are numerous of these incidents, i feel like it is the gauge. Anyone have experience with glowshift support?
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
Blue Spring | FP Gauge
PMM Coolant Filter
Leveled|35's
LED Reverse|Bed Rails
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #10 of 11 Old 07-24-2013, 12:41 AM
Joeshu1000's Avatar
Originally Posted by pcris View Post
I installed my fuel psi gauge about 3 months ago and just started experiencing issues with it bouncing high and pegging out at 100. I made sure I installed the sensor and all under the hood very carefully so I don't think it's the problem, and seeing as there are numerous of these incidents, i feel like it is the gauge. Anyone have experience with Glowshift support?
Mine was doing the same thing and the fuel pressure sending unit went bad. It seems to be a common thing. Glowshift replaced mine under warranty.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
