Pulling Carnage! - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-22-2013, 11:09 AM Thread Starter
ZIKA's Avatar
Pulling Carnage!
I have brought this up before but, every good running Ford I see breaks its drivetrain at every Pull. Yesterday I was at a pull in Muntua OH and there were 78 Trucks. One of those trucks was the "2013 Diesel Power Challenge Winner." I took a picture of his truck with the banner on his window but very blury.
Either way... He pulled 284 and broke his rear drive shaft at the splined portion of it. Super Clean break to wear it look machined. Then I pull... 279 and bang. Hopped out of the truck and nothing hanging. My left rear wheel was making crazy noise when driving it slowly in the pits. Both trucks broke within the last foot fo the pull. Oh and obviously he didnt spray his nitrous... Pulled the left rear shaft and oh yeah.. its broke. When it broke, it was like a spiral fracture and left alot of debris in the axle tube and the axle is stuck in there. (Super Stuck)
I am hoping that the center of my detroit locker is open and it doesnt have a pin down the center of it so I can hammer it out from the other side.
Questions:
-Any input on getting out the broken shaft?
-Has anyone ran Yukon Axle shafts? Good or Bad?
-Is it worth spending $560 on shafts or try to find a Dana80 and make it fit or...One of those AAM1150's out of a Dodge or Chevy and change my rear wheels.
Just a side note. This is 4th gear set and now this happens. I have lost faith in this rear end. Just venting
ID:	143490   Click image for larger version
ID:	143498   Click image for larger version
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #2 of 16 Old 07-22-2013, 12:27 PM
strokin6L's Avatar
Quoted: 3 Post(s)
I've pulled my truck a dozen times or more and never had an issue with the rearend or drive shaft. Only trucks I've seen break the drive shaft or rearend around has been either a Chevy or a dodge. I think the ford rearend and shaft can take a beating. My truck is only making 525 tops...however once you get over that 600 mark then I'd start beefing it up. Another thing...lifted trucks with big tires don't do good truck pulling....chit breaks then. The lift and big tires are a big downfall
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 16 Old 07-22-2013, 12:38 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Notice where it was happening. It all has to do with wheel hop and traction induced over-torque. I don't know if you are using traction bars to prevent axle wrap and what the front end was doing, but either of those will vary the load enough to snap axles.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 16 Old 07-22-2013, 12:41 PM
Therabbittree's Avatar
The Dana 80 is stronger, then a 10.5 Sterling / Ford rear. Even the dana 80 can grenade. many guys swap the axles out asap on the 80's.
The 11.5 is supposed to be stronger or as good as a 80. Coprate 14 and 80 are good too. Read up in some of the pulling threads at Comp Diesel. Lots of 800 plus hp Cummins and Duramax puller over there.
AAM 11.5 VS Ford 10.5 - Competition Diesel.Com - Bringing The BEST Together
Therabbittree is offline
post #5 of 16 Old 07-22-2013, 12:54 PM Thread Starter
ZIKA's Avatar
I will agree that the 37" put a ton of load on the shafts but once I swapped in those 4.56's, man it pulls good. it also made it alot better once I built rear suspension stops. As for wheel hop, it doesnt hop at all. I am running stiff bars in the rear and a front 4 link. I thought about dropping it 2" and running 35's but I would have to do another gear swap down to a 4.10 because I am running 2300rpms on the highway as it is. Im not sure if you saw my last post but I have seen guys roll the rear diff on the axle tubes last year and this year with the Sterling. I was just thinking that the Yukon Shafts may make the difference. I always seem them break with in the last 3-5 feet when the truck is really digging and the converter is locked. I have never seen an AAM break but I have seen a couple Dana80's Break but that was in a 3.0 truck that is probably making 1000HP when I would be lucky to hit 450-460.
ZIKA is offline
post #6 of 16 Old 07-22-2013, 12:56 PM Thread Starter
ZIKA's Avatar
Strokin6L, Do you remember if the middle on your detroit is open or is ther a pin in the way. I am really sweating getting that broken shaft out.
ZIKA is offline
post #7 of 16 Old 07-22-2013, 01:10 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
I have seen a Sterling rear twist on the tubes and it was at the end of the pull and was hopping a Lil bit with 40" tires. I never had an issue with the Sterling in my 97, but i wasn't pushing the power y'all are talking about. I just had some stage 1 sticks and an h2e turbo kit with citation tunes. But i did have 37" iroks with 4.56 gears and wrap bars and I beat the piss out of that truck when i was pulling with it.
I really wish someone made a conversion hub for the aam 11.5. That rear end i had in my dodge was far superior to these Sterlings, the pinion and ring gear is just massive.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #8 of 16 Old 07-22-2013, 01:22 PM Thread Starter
ZIKA's Avatar
Those AAM's are huge! You see the 2.6 guys who are making a 1000hp running stock shafts and gear set. when you lay them side by side to a Sterling, it makes it look tiny.
ZIKA is offline
post #9 of 16 Old 07-22-2013, 01:57 PM
Quoted: 761 Post(s)
I'm not much into pulling but what about using DANA 110 out of an F450??? Idk.
As far as removing the axle, just remove the hub. It appears its not broke off very deep. After you remove the hub. Should be able to just pull it right out.
Corey@CNCFAB is offline
post #10 of 16 Old 07-22-2013, 02:07 PM
The axle shafts in my F450s Dana s110 has 1.55" axle shafts. I broke one already. On that one I pulled the opposite side axle, slide the shop broom handle through the differential and pushed the broken stub out
harrisford is offline
