BPD let me down???? - Ford Powerstroke Diesel Forum
post #1 of 44 Old 07-21-2013, 05:38 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
BPD let me down????
As you may or may not know Ive been a bit concerned with my EOT. You can read all about that here-http://www.powerstroke.org/forum/6-0l-performance-parts-discussion/458058-05-grill-ideas.html
And now today I find out that Bullet Proof Diesel has worked on and is now selling-There are two types of coolers for the Bullet Proof Engine Oil Cooler System:
Heavy Duty cooling is best suited for low-geared F350 Dually, F450 and F550's or those that tow often or heavy. The heavy duty cooler is a $150 upgrade over the standard duty cooler.
Standard Duty cooling is great for F250 and SRW F350 chassis.
^^^This was copy/pasted straight from there site.
Maybe Im way off base,but I just installed the total BPD oil cooler set up in October. You cant tell me that in October they didnt already know there might be a issue with the low geared F350 drw trucks and there cooler set up.
So now Ive already bought and installed a new grille thinking I had bad air flow issues. And it looks like now Ill be buying the upgraded cooler.
I dont know maybe be off base with this but I feel like BPD kinda let me down.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 44 Old 07-21-2013, 05:44 AM
BPD should have had some kind of announcement on their website That they were working on an HD kit. That way ppl that were on the fence, or doing it for preventative measures would know something was going on.
Moto2four is offline
post #3 of 44 Old 07-21-2013, 06:06 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Upside is I always di want to do the bypass filter and that would be a great time for it. And it will help them buy another Prius
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 44 Old 07-21-2013, 06:51 AM
usnavyad's Avatar
Feedback Score: 3 reviews
I kinda agree when I did my build 6k ago I wish I would have know bdp was coming out with a new oil cooler cause I would have went that way instead of a new oem
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #5 of 44 Old 07-21-2013, 07:33 AM
F250SixOH's Avatar
Maybe they could offer an "upgrade" kit for people that already have the existing kit?
F250SixOH is offline
post #6 of 44 Old 07-21-2013, 07:43 AM
mach65's Avatar
Quoted: 138 Post(s)
It's all about the money for BPD. Like any other company in the business of selling products.
2005 Lariat CCSB
Stock Motor
124,500 miles
edge insight cts/egt probe
coolant pressure gauge in cab
high idle mod
muffler delete
cat delete/stock straight pipe exhaust
IPR coolant filter
EGR welded shut
mach65 is offline
post #7 of 44 Old 07-21-2013, 08:31 AM
portcity_gt's Avatar
Quoted: 1358 Post(s)
I still wonder if there's something going on with your truck. The highest my eot has ever gotten was in the 220's.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #8 of 44 Old 07-21-2013, 08:37 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm going to disagree with this here. BPD cares a HELL OF A LOT more about the products they sell than just making money. You can tell this if you've ever bought anything from them such as their oil cooling kit. The quality of these kits is second to NONE. Now whether or not it was right of BPD to not post up anything about their "HD cooler" is TOTALLY debatable.
I personally am of the opinion that it doesn't do really any good to announce that you're "working" on developing something new and improved because then you end up like Diesel Site, over 8 years after a truck is released and now discontinued with two different diesels released, and still no "upgraded" HPOP. Does Diesel Site care more about their products than BPD?? I would argue that they don't. I believe both companies care a great deal, it is just that BPD chose to not say anything about it.
My recommendation to the OP would be to call Ken or Neal and see what they can do you for you. I know that they are both AWESOME guys to deal with. Hope this helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 44 Old 07-21-2013, 09:02 AM
Snake's Avatar
Quoted: 46 Post(s)
If you have air flow issues, an upgraded cooler may or may not help. There's a lot of variables and it may require a combination of changes. I did just read the thread about your EOT concerns you linked and it sounds like the new grill resolved your issues. Is there a reason you're still considering buying the upgraded cooler? I'm guessing you'd like to go back to the grill you just replaced, and if that's true then I'll ask you to reference my first sentence again.
Have you already contacted Bulletproof Diesel and told them about your concerns?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #10 of 44 Old 07-21-2013, 09:05 AM
Snake's Avatar
Quoted: 46 Post(s)
Please tell me what you're basing this statement on. It's been the exact opposite in all of my personal dealings with Bulletproof Diesel and 99.99% of those that I've heard about.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
