More Airdog BS!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-19-2013, 09:37 PM Thread Starter
05diesel60's Avatar
More Airdog BS!!!
So I've had an airdog 2 on my truck from early 2012 until June 2013 working without problems until the fuse blew. So I did some research and found that many were having problems. I called airdog and asked them about it and they told me that in August of 2012 they came out with an "updated" unit. So I am working overseas and cannot do anything myself, so I have a trusted mechanic that does my work for me. He installed the new unit, did the relay and upgraded the wiring harness and reset the fuel pressure back to normal. He primed the truck and went to fire it up and during cranking it dropped from 60psi to 10psi. So he took the new unit off and replaced with the old and fired it up and it held 60psi the entire time. So this supposedly "brand new" airdog unit is screwed from the start and now I have to get another one from them and they are closed on weekends and I'm pissed because now its just a mess.
Anybody else with similar issues? When I get home I am going to disassemble the original one and figure out if I can replace the gerator pump, rewire and reassemble with with a brushless motor and upgraded wiring and try to make a one-off airdog unit. I'm not sure if it can be done but I'm going to give it the ol' college try and see if anything good comes of it. Anybody else try to take one apart and rebuild?
2005 Powerstoke CC SB Lariat
SCT X3 Tuned by Eric @ IDP
, Edge Insight, FICM Upgrade with Re-flash, Fabtech 6" Performance Lift with 35" M/T Baja ATZ's, Banks Turbo Back Dual 4" Exhaust, Kitty Delete, Banks Intake, Banks High Ram Intake, Banks Intercooler, Garrett Powermax, Casserly 155cc Injectors, AirDog II, Blue Spring Upgrade, 6.4 Banjo Bolts, EGR Delete Kit, Mag-Hytec Rear Diff. Cover with Eaton True Trac, CAT ELC, ARP Head Studs, Royal Purple Oil, Rev X Oil Additive
05diesel60 is offline
post #2 of 6 Old 07-19-2013, 10:33 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
It is a common story .... A more reliable setup seems to be using the 6.4 pump as a lift pump feeding the stock hfcm .... If big hp is your goal look into a fuel lab pump setup. I myself would sh!t can anything that said airdog if it were on my truck.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #3 of 6 Old 07-20-2013, 03:43 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 104 Post(s)
My AD100 seems to do it's job quite well. Another buddy has been running the AD150 for awhile too with no issues. AD II units are the problem child not AirDog in general.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 6 Old 07-20-2013, 08:06 AM
Quoted: 5 Post(s)
Based on pure flows record of some garbage products and even more pathetic customer service I wouldn't give them a dime of my money. And if it was on the truck working perfect or not it would have hit the bottom of my garbage can!
True Blue Metallic
post #5 of 6 Old 07-20-2013, 09:05 AM Thread Starter
05diesel60's Avatar
Yeah I just haven't heard of anybody coming out and saying "THIS is the right setup, use THIS" so it's kind of hit or miss. I hear FASS is just as bad and I was finding some things on here about fuel lab being somewhat new with their water separator I don't want to be the guinea pig that buys yet another unit for more failing crap.
Hopefully somebody has used the fuel lab setup and will chime in here and give their
post #6 of 6 Old 07-20-2013, 10:10 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1655 Post(s)
My AD2 is now a lift pump turned all the way down to my factory HCFM. Never drops bleow 60psi with this setup even at WOT.
toren302 is offline
