Did ARP make natural metal headstuds?... and a question on warren sticks - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-18-2013, 07:10 PM Thread Starter
gotta_gofast's Avatar
Quoted: 61 Post(s)
I have the 6.0L torn down and noticed the head studs (which were installed before I took ownership) are silver... not black like the ARPs I have seen (but they have the hex key drive recessed into the stud and 12 point 18mm nuts like ARPs). Did ARP ever produce studs without the black coating? Any other stud manufacturers out there?
Also, 3 injectors are showing weakness so I'd like to upgrade while the engine is out. I see guys running 155/stock injectors and I would like to do the same. Just wondering where you've purchased them and if you would do business again... and if you've had any problems. Also, how long should one expect to wait for injectors? It will most likely take 7-10 days for the machine shop to do my heads but I don't want to be without the truck for a month waiting on injectors.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #2 of 21 Old 07-18-2013, 07:27 PM
ZMANN's Avatar
Quoted: 1661 Post(s)
there are a few others like h11's and I think ARP had a different option at one time also
We Miss you Ronnie
ZMANN is offline
post #3 of 21 Old 07-18-2013, 07:31 PM Thread Starter
Quoted: 61 Post(s)
There are no markings on the studs. They do not look stressed or beat up and I would like to re-use them... it would be a shame to throw good parts in the garbage because I don't know what the torque specs are. The studs were installed a few years ago.
post #4 of 21 Old 07-18-2013, 07:31 PM
Like a boss!
Laferty's Avatar
Near the hex socket on the stud it should say ARP 2000 I believe. Haven't seen mine in awhile thankfully. Lol.
I did injectors through Warren Diesel and so far no complaints. Great customer service. Took about 10 days but I was told they were moving the shop so that caused a delay. No big deal and I don't feel like they were lying about it.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #5 of 21 Old 07-18-2013, 07:33 PM
ZMANN's Avatar
here is the pic of the H11
We Miss you Ronnie
ZMANN is offline
post #6 of 21 Old 07-18-2013, 07:36 PM
Like a boss!
Laferty's Avatar
H11's are bigger and require the hole to be drilled and threaded correct? Call ARP. They should help.
2006 CCLB
Laferty is offline
post #7 of 21 Old 07-18-2013, 07:39 PM Thread Starter
Quoted: 61 Post(s)
Tomorrow after work I'll make a few phone calls. These are natural metallic not gray/silver coating like the A1s pictured. Maybe they're specials from the hardware store? lol
post #8 of 21 Old 07-18-2013, 07:41 PM
sprksonu's Avatar
don't throw them in the garbage mail them to me i will pay for shipping!
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #9 of 21 Old 07-18-2013, 07:41 PM
Feedback Score: 5 reviews
No, H11's are the same size. No drilling or tapping required. My H11's from Elite are the silver color that the OP is talking about...
'04 F-250 Lariat CCSB FX4
Elite H-11 headstuds, BPD oil cooler, BPD bypass oil filter, BPD Waterpump, BPD 58 volt FICM,mWarren 175/30's, KC Stage 3 68mm turbo, Andy Warren Comp plus tranny, PI Stallion, Sinister EGR delete, MBRP 4" exhaust, Dieselsite coolant filter, ELC, Edge Insight CST, SCT SRL++
yfzjim is offline
post #10 of 21 Old 07-18-2013, 07:42 PM
ZMANN's Avatar
seriously who would do that ?
they are the same plug and play as ARP just a different composition
We Miss you Ronnie
ZMANN is offline
