Can you turn off the egr CEL with the SCT - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-18-2013, 06:57 AM Thread Starter
I have the EGR delete and my truck shows the CEL as a result. I also have the model 3015 SCT tuner to turn it off when I am running the custom tunes from Gearhead. My question is can I run the truck stock and turn off the CEL? I have just come in from hooking the tuner up and scrolled through every menu I could in trying to find a menu to go into in order to turn off the egr, am I missing something?
waumpuscat is offline
post #2 of 7 Old 07-18-2013, 07:35 AM
snafu!'s Avatar
Matt at Gearhead turns the egr off in the tune so you won't have the option in the menus to turn it off.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #3 of 7 Old 07-18-2013, 08:45 AM
strokin6L's Avatar
Quoted: 4 Post(s)
The SCT does it automatically... no matter if its custom tunes or canned tunes.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 7 Old 07-18-2013, 09:18 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
Thumbs up
On my 3015 u go under adjust opt then saved opt it will list tune Egr tow brake arrow done to Egr hit select then on or off .
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
post #5 of 7 Old 07-18-2013, 09:58 AM
texaslimeaide's Avatar
I have the SCT TSX and when I return. To stock I can't turn off the egr. The reason is that its STOCK. Ford programing was for the egr to function so the stock program will cause the CEL to illuminate if you have and egr/valve delete.
Sent from my Nexus 4
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is offline
post #6 of 7 Old 07-18-2013, 10:10 AM
snafu!'s Avatar
snafu! is offline
post #7 of 7 Old 07-18-2013, 10:32 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
The SCT devices most be different between models then , I just got done setting my truck back to stock and turned of Egr !! Even though I have one (BPD ) I leave turned off when running stock tuning
s:
