MTW 11 blade single plane 03-04 stock replacement billet wheel - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-16-2013, 04:51 PM Thread Starter
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
In an effort to go all out with the 11 blade single plane design, MTW has developed the 11 blade single plane billet wheel for the 03-04 turbos. It has the exact same specs as the MTW 05-07 stock replacement wheel with the exception of the size of the inducer, which is 59mm as opposed to 56.7mm, the same size as the 03-04 turbos.
Here are a couple of pictures.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #2 of 8 Old 07-16-2013, 04:53 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Nice wheels Nate! Question. Do you have wheels for the refurb factory turbos? I think they're smaller
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 8 Old 07-16-2013, 04:59 PM Thread Starter
BACKYARDIGAN
Quoted: 4 Post(s)
Thanks Oliver!!
The "remanufactured" turbos are often the same size as the 05-07 turbos. Sometimes a reman turbo will be the same size as an 03-04 turbo. It all depends on the Garrett P/N from what I can tell. The best way to go about it is if you have questions to simply shoot me a PM and I'll be happy to help as best as I can.
Nate
post #4 of 8 Old 07-16-2013, 05:05 PM
bondajb's Avatar
Wouldn't it be better to refer to it as a 59mm rather than 03/04. I say this because my 05 has the 59mm not the 57mm as the year suggests... and yes it is a remand stock turbo.
looks impressive Nate..
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #5 of 8 Old 07-16-2013, 05:06 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
Awesome! My buddy mike has a refurbed on a 05 ill try n measure it and get one ordered from you!
Oliver
ODAWG714 is offline
post #6 of 8 Old 07-16-2013, 05:31 PM
portcity_gt's Avatar
Quoted: 1361 Post(s)
Looks like you need a test mule!! Hint hint.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #7 of 8 Old 07-16-2013, 06:08 PM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
Looking great Nate.
Keep up the advancements...
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #8 of 8 Old 07-16-2013, 06:28 PM Thread Starter
BACKYARDIGAN
Quoted: 4 Post(s)
I guess so Aaron. It's tough to classify them by p/n, which I believe is why most places sort them by year. As I mentioned though, it's not too big of a deal to try and determine what size wheel a given turbo has before someone gets a wheel. And while it sucks, we are always happy to swap it out for free.
Cool. Sounds good. I'll just have to direct him to Adrian as he is the one that actually has the wheels. Of course I'll answer any questions.
Originally Posted by colo_dually View Post
Looking great Nate.
Thanks Ben
Nate
