SCT tunes and Atlas 40 FICM tune - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-16-2013, 12:44 PM Thread Starter
seanol's Avatar
I had my FICM done by Ed and the Atlas 40 installed at the same time. I already had my sct tune (Looney Wild) in the ecm. If I want to go back to stock or change tunes, do I need to do anything to the FICM so I don't lose the Atlas 40 tune?
I know the SCT does not tune the FICM, but does it have any effect on it at all? Do I need to pull the relay for it?
I don't want to lose my tune so I figured I would ask before I have an issue.
Thanks,
Sean
seanol is offline
post #2 of 11 Old 07-16-2013, 12:58 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The FICM tune is locked in, you won't lose it when tuning the ECM/TCM with the SCT. You do not need to remove the FICM relay when tuning with the SCT. Your good to go.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 11 Old 07-16-2013, 02:03 PM Thread Starter
seanol's Avatar
Thanks!
I was reading in another thread that to tune the FICM one would need to pull the relay and I wanted to make sure I didn't erase anything.
Much appreciated,
Sean
seanol is offline
post #4 of 11 Old 07-16-2013, 02:14 PM
Powerstroke Techie
Lilpooh's Avatar
Originally Posted by seanol View Post
Thanks!
Much appreciated,
Sean
Yes, when you tune the FICM, you need to remove the relay. When you tune the PCM/TCM, you don't need to remove any relays.
Lilpooh is offline
post #5 of 11 Old 07-16-2013, 02:44 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 115 Post(s)
Juts a cautionary note about FICM tuners. With your FICM hard tuned with the Atlas 40 do not buy a PHP FICM tuner to try other tuning levels. Seems as the FICM tuner will load other levels but will not let you "go back to stock". Therefore the PHP FICM tuner is locked and cannot be used on another truck if you sell it. Seems it's just the way the tuner worked at the time from my conversation with Bill. Last I knew this issue still exists but Bill might have fixed it by now.
I'm all for PHP products this is just a FYI if you want higher levels on you hard tuned FICM.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 11 Old 07-17-2013, 09:55 AM
mrenn's Avatar
Quoted: 3 Post(s)
Those charts on PHP's website are pretty impressive even for just a ficm tune.It really makes that much of a difference to tune the ficm?
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #7 of 11 Old 07-17-2013, 10:25 AM
Over stock, yes.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #8 of 11 Old 07-17-2013, 10:26 AM
Aretoo's Avatar
I had Atlas 40 on my truck before I put the gear head tune on it and it made a noticeable difference. Especially on the low end. Was worth it in my opinion.
My only word of caution is be careful pairing your FICM tune with your SCT tune on a stock truck. It will cause you to get some pretty high EGT. I had this combo before my mods and I believe the high EGT were a major contributor to my ruptured head gaskets. My right foot may have had a little play in it also.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #9 of 11 Old 07-17-2013, 11:31 AM
Chatham036's Avatar
Quoted: 136 Post(s)
I could be wrong here.. But I have yet to hear of high EGTs causing head gasket failure.
I have heard of high EGTs warping turbo vanes and causing valve issues.. but not head gasket failure.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #10 of 11 Old 07-17-2013, 12:22 PM
Aretoo's Avatar
To be more specific I believe the high EGT and in turn high cylinder temps was one of the leading causes of my heads warping causing my head gaskets to lose their seal. Here is what happened.
I made a run one day where the EGT got in excess of 1500*. It was a long hard run. I started with an aggressive acceleration (not just slamming the pedal to the floor) and held it until about 95 mph. During that time my CTS showed temps in excess of 1500*. The boost never got above 24psi and the "boost gauge" never showed red on the dash. I was running a tune for a non studded truck and Atlas 40. I had been under the hood just a day before and had no puking and no excessive coolant pressure when opened. Approx. 2 days later (normal driving) I opened the hood and found my coolant bottle had puked coolant all over. I did a Blok-Chek and it turned positive immediately. BUSTED!
When I had my truck studded the heads were warped about 8 thousands. Di I think it was just the temps that caused it, No. But I also think that it had a very large part in causing my failure.
NOTE: Just so there is no confusion. I do not hold the tune writer or PHP in any way responsible for my failure. I put them both on my truck knowing that that was a possibility. I have been very happy with both products and now that my truck is studded have them both back on my truck again. I just want to warn people so they do not make the same "mistake" I did. Although I am not sure how much of a mistake it was, I not have a studded truck!
MODS
ARP Studs
IPR Gen2 EGR Delete
MBRP 4" turbo back
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
