Trans temp gauge. - Ford Powerstroke Diesel Forum
post #1 of 22 Old 07-16-2013, 08:25 AM Thread Starter
southern raised's Avatar
Trans temp gauge.
Hey im getting my gauges hooked up today and my mechanic is saying he cant hook up my tranny temp prob because i have a stick oil pan, this is BS isnt it? I believe 90% of ppl that have gauges have stock oil pans, is he right?
southern raised is offline
post #2 of 22 Old 07-16-2013, 08:29 AM
Chatham036's Avatar
Quoted: 136 Post(s)
If you are running analog gauges, there should be a test port on the left side of the trans that the sensor can go in. I know there is one on the 7.3l anyway.
Most 6.0l guys run digital gauges which read off of the OBDII.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #3 of 22 Old 07-16-2013, 08:31 AM Thread Starter
These are borh digital and analog
post #4 of 22 Old 07-16-2013, 08:32 AM Thread Starter
Whats the test port look like? A screw or is ot noticable?
post #5 of 22 Old 07-16-2013, 08:43 AM
snafu!'s Avatar
Came across this a while back, it shows the test port on the trans.
Auto Meter
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 22 Old 07-16-2013, 09:31 AM Thread Starter
Do u know were the fuel pressure sensor goes?
post #7 of 22 Old 07-16-2013, 10:29 AM
snafu!'s Avatar
The FP sender goes on the fuel bowl test port it is kinda hard to access because of the upper radiator hose. I used a 90 to keep the sender away from the hose, strictly diesel sells a relocation kit for the sender that works really well.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
post #8 of 22 Old 07-16-2013, 11:37 AM Thread Starter
I just took the radiator hose out to put it in at the hole is too small, you think advanced sells a fitting for that?
post #9 of 22 Old 07-16-2013, 11:59 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The adapter fitting for the FP is M12x1.5 male (o-ring boss) to 1/8npt female. Not sure if the "box store" auto parts carry it. Most hydraulic shops carry the fitting.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 22 Old 07-16-2013, 12:58 PM
snafu!'s Avatar
^^^what he said. I got the adapter from my local Parker dealer.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
