Stiction Revisited - including plunger stiction - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-13-2013, 08:16 PM Thread Starter
twoicebergs's Avatar
Quoted: 47 Post(s)
I wasn't completely sure which section to post this in, but since this is a bit more advanced than replacing a part, I thought it would be better in this section.
I asked a friend for an injector coil section and that I didn't care of the condition of the rest of the injector. He pretty much gave me an injector for a modest fee. Just for giggles I took it apart to see how bad it was. The outside looked quite good, except for a caked nozzle and very dirty residue on the injector. Externally it cleaned up very well. Internally the spool and the plunger were stuck and the nozzle was not too bad. There was no scoring internally, it was all varnish. Needless to say, the injector was not working when it was taken out of the engine it came from. I worked on it for about 10 minutes to clean it and free up the stiction. 800 grit on the spool for a few twists and a core soak in brake cleaner with a very small brush to clean the tip of the bore. I also sprayed the nozzle to confirm the 6 holes were clear. Don't do this without planning the spray pattern, it will actually spray quite a distance out of the 6 holes of the nozzle. The injector is very tight and visually very nice with no rubs or scoring. I would have no concerns with putting this in any 6.0. Here are the videos of the diagnosis and after the fixes.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 23 Old 07-13-2013, 08:47 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Excellent videos Frank!!!
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #3 of 23 Old 07-14-2013, 12:43 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
As always Frank, well put and nice videos!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 23 Old 07-14-2013, 05:03 AM Thread Starter
Quoted: 47 Post(s)
In the first plunger video it is tough to tell just how hard I am pushing the plunger to get it to move. At the start, a guestimate would be about 10-15 lb-ft of force. It lessened the more I exercised it past the stuck section. In the second video it moves full length on its own weight. The needle in this one moved quite well. In one of the other injector nozzles I had honed, it took about 15 minutes to get the nozzle out. as it turned out, even that nozzle was usable and is still in service!
Someone asked, "why not just buy a new one?" My answer was the best option is to always get a new one with all new parts (meaning the best reman). If you do your own work, this is always worth considering; but know when to spring for the new reman. However, this can be the equivalent to a good rebuild. You get to see the condition of all the parts before it is put together. This injector after cleaning was in as good condition as any of the remans I had previously opened to modify! There is no doubt that DLC is a great process!
Frank
Working for Toys
post #5 of 23 Old 07-14-2013, 05:08 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Frank I think I missed it man. What did you use to clean the fuel plunger/bore?? I agree, with how free everything looks in those videos, I would pop that sucker in my truck for sure. Looks good.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 23 Old 07-14-2013, 05:41 AM Thread Starter
Quoted: 47 Post(s)
The last 1/8"-1/4" of the bore was the problem. I used a small brass brush and some brake cleaner. Less than a minute to clean and re-lube. Initially I thought I might have to use some grit paste, but I didn't have to. I added the comments to the You-tube channel, but they don't show up here embedded.
Frank
Working for Toys
post #7 of 23 Old 07-14-2013, 05:47 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Ah I got ya. Thanks for the information. I'll probably give this a whirl too. Thanks again Frank.
Nate
post #8 of 23 Old 07-14-2013, 07:32 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Great stuff Frank. You continue to take a lot of the mystery out of our injectors for the members here. Thanks for sharing the knowledge.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 23 Old 07-14-2013, 06:21 PM
colonel angus's Avatar
Quoted: 2 Post(s)
What test can a person run to check for stiction?
Is it likely to hit one injector, a couple, a few or all?
Would you just address 1 and wait for another or do them all ?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #10 of 23 Old 07-14-2013, 06:51 PM Thread Starter
Quoted: 47 Post(s)
In the simplest form it is spool stiction, most notable during cold starts and during warm up. Except for the misfires or rough running you could test via a power/contribution balance test.
It may affect one or more. The chances are it will affect more than one, it usually takes 2 to create enough grief to take it in to get fixed. With worse maintenance, it is likely to affect more or all of them. If you pull one and have stiction, you have 2 courses of action. If it looks really clean it might be better to just do the bad one. However, for the time it takes to inspect all on the same bank, it might be worth the time to do it. It is really a judgement call, maybe you do gambler's choice and inspect another one to determine if you go further.
Frank
Working for Toys
