EBP 2005 Anyone monitor thiers ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-13-2013, 05:32 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Wondering what the range is supposed to be.
I average 13's when idling up to 43.1 WOT on the highway.
Normal or ALARMING!!!!
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 8 Old 07-13-2013, 05:45 PM
bondajb's Avatar
That sounds more like map not ebp..
ebp at idle will be 2psi during a engine cycle might go from 0-7... and I believe the sensor maxes at 37-40
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #3 of 8 Old 07-13-2013, 06:04 PM Thread Starter
Quoted: 2 Post(s)
hmmm, lemme go get the Scangauge values....
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #4 of 8 Old 07-13-2013, 06:08 PM Thread Starter
Quoted: 2 Post(s)
Anyone have the Scangauge EBP values?
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #5 of 8 Old 07-13-2013, 06:12 PM
bondajb's Avatar
Strange those values would be different. .. I have a 0-100 sensor hooked up plus my cts read it out of the obd and both values are identical
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
post #6 of 8 Old 07-13-2013, 06:26 PM Thread Starter
Quoted: 2 Post(s)
BST = 07e0221440 txd 046285140640 rxf 3010 001d0050ff73 mth
EBP 07e0221445 txd 046285140645 rxf 3010 001d00500000 mth
I have it set to read BST options are BST or MAP which is preferred?
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #7 of 8 Old 07-14-2013, 06:19 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
It's showing the baro pressuer added to the EBP. Subtract the baro pressure for you local area (estimate 14.5) and that's the EBP. Compare that to the boost PSI to see your ratio.
Baro pressure for your area may be 13PSI so your EBP at idle is really 0. For my area baro reads 14.5, EBP 2, Boost 0 at idle.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 8 Old 07-14-2013, 07:46 AM Thread Starter
Quoted: 2 Post(s)
Saw that now it's corrected in the MTH FF72 it was 14.2
Thx.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
