Boost psi at back of intake manifold? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-12-2013, 11:04 AM Thread Starter
Just wondering if anyone has measured the boost at the end of an intake manifold versus the input ?at the turbo, at the intake and output of the intercooler?
All this fab work being done why not put a test port at the end to prove full psi is delivered to all intake ports? If there are such gains peeps claim with what is currently being done, I have to imagine there is more still out there.
I've seen this done with fuel and oil rails, with surprising enough results that caused folks to make modifications to better even flow.
I wonder? If a central fed H style intake would deliver more even flow. Or what about a common intake chamber, I can't picture that on a 6.0. Kinda what I've seen in a dodge gasser.
Also how does the stock or modded 6.0 intake runners compare to the intercooler piping volume. With regards to volume i meas cross sectional, like a larger pipe flowing into two smaller that equals the first larger.
Does the flow expand volume and slow down because the runners are bigger and have consumption or does the air speed up due to restriction?
This is very interesting to me because air is a compressable and this adds another twist on plumbing things. Especially since the air psi is relatively low 20-40psi with lots of volume/distance to travel versus say non compressable fuel at 60psi in a thin fuel line. I feel like some folks just cumminsate i mean compensate for all this by just shoving 50-100psi with big turbos.
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #2 of 12 Old 07-12-2013, 11:28 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 134 Post(s)
Feedback Score: 3 reviews
I could modify my GOGO covers to add a port for a sensor, but then I'd need the sensors for my Insight. I could then add a sensor to my intake elbow as well.
I don't think you would see the PSI readings you are expecting. Since EBP is post intake manifold that seems reasonable to compare those readings to the MAP or aftermarket sensor in the intake elbow.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 12 Old 07-12-2013, 12:41 PM
If I remember right, the Scan Gauge takes it's input from the MAP, which has a port on the right side about mid manifold. That being said, with my Scan Gauge hooked up AND my Auto Meter gauge in the elbow, they were both within a pound of each other.
I don't think either intake has anymore boost front to rear because it is, for all intent and purpose, a pressurized system. However, polished runners to have the advantage of smoother flow.
Have you ever port matched a gasser intake? It doesn't take much to show an improvement.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 12 Old 07-12-2013, 01:58 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
My stock gauge, Edge Insight, and Autometer in the Intake Elbow all read pretty much the same.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 12 Old 07-13-2013, 07:15 AM Thread Starter
I am just questioning the science of the intake mods.
I have no doubt they work but exactly why could be the direction to improve upon.
Has any one ever dyno'd a rig with stock then modded intake same day? Varied set ups?
Has any one done real world psi monitoring at the ends of the runners to prove before and after gains?
Seat of pants and bench flows don't cut it.
I'd buy it if say you dyno'd your truck before more then once with another truck and both layed down consistant numbers, then one truck ran the modded intake with the other truck same day running as a control to the experiment to ensure consistantcy. When I hear some one say "i do not know, it feels stronger". I think of the placebo affect.
Important stuff:
frashdog is offline
post #6 of 12 Old 07-13-2013, 07:25 AM
N.S.D.Q.
Quoted: 134 Post(s)
Okay. Send me the money and I'll dyno my GOGO then swap back in my stocker. The info will be yours exclusively to use. I'll sign any non-disclosure statement required.
If that's not reasonable then come for a ride with me and see what stock injectors feel like with airflow improvements.
post #7 of 12 Old 07-13-2013, 08:18 AM
madpowerstroke's Avatar
I believe that someone has done a stock intake vs a ported on on a dyno. Thinking it might have actually done with a go go intake. I know and I'm sure that others with a ported intake will tell you that they saw a decrease in egt about 100-200 degrees. That in itself is showning that the engine is running more efficiency. Weather it's gained air flow or back cyclinders are getting more air let engine run efficiency, the decrease in egt shows a difference.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #8 of 12 Old 07-13-2013, 11:11 AM Thread Starter
First of I'm not doubting anything. Just want to see scientific proof, can't be that hard.
Second what ever gains have been made with the great effort put forth should be continued in the most efficient manner.
If some one has the capacity to step up, or already has, do so and create a sticky on the matter please.
Important stuff:
frashdog is offline
post #9 of 12 Old 07-13-2013, 11:18 AM Thread Starter
Why does the last intake port need the same size runner as the first? That does not make sense to me!
In other words... The first intake port has it's flow and the next three flows flowing by the second has its and the next two and so on. Can't picture the last one getting its needs met as the loss increases and volume stays constant. So maybe a stepped down runner would be better. Hey maybe a giant runner with storage would be better.
I do not know.
Important stuff:
frashdog is offline
post #10 of 12 Old 07-13-2013, 11:48 AM
licenced2burn's Avatar
I think since this is a pressurized system you don't need a stepped down intake or anything like that. Its "forced induction" so its forcing as much air as possible into each port. The increase you see from porting an Intake will be from removing the blockages that cause turbulence and restrict flow. I could see the back cylinders getting a little less air but once the restrictions are removed I by porting I think that the air flow will be very close to all cylinders. The only way I see anyone making a much better flowing intake would be a tunnel ram style
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
