2wd to 4wd - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-12-2013, 09:03 AM Thread Starter
Rick C's Avatar
2wd to 4wd
I'll try to keep this short. Has anyone out there ever researched the issue of converting a 05 or later F-450/550 from 2 to 4 wd??? I am wondering if the axel swap is just a matter of pulling the straight beam and replacing it with the drive axel. The transfer case issues don't seem to be too big of a deal. Or should I just be !
2005 F-450 CC Fontaine Conversion
(It's the heavy GVW one with the Dana 135, 4:88's and bigger brakes)
Link Air Ride Suspension
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 with Eric's tunes
Bullitt Proofed (EGR mod, Remote oil cooler/filter, Water Pump, 7.3 fan clutch conversion)
ScanGaugeII
Odyssey AGM's
High Idle Mod, CCV Mod
ARP studs...Finally
More $$$ to be spent i'm sure!
Rick C is offline
post #2 of 3 Old 07-12-2013, 03:56 PM
Dirty_Stroke's Avatar
I have no personal experience swapping a 450/550 to 4wd but a 250 is very simple. It literally is just a matter of swapping the I-beam out for an axle. Two things to think about on the 450 is the front axle your going to use. Them trucks use what Ford calls a "Super 60" Dana 60 which is 10 lug and has sharper turning radius and larger u-joints than the Dana 60's in the 250/350 Superduty's. It will probably be hard to find. Secondly, what transfer case to use. I'm not sure if the 450/550's use the same transfer case as the smaller trucks. They might, but that you need to research.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 3 Old 07-13-2013, 06:50 AM
Guy I know has f550 front 4x4 axle. It's just straight swap
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
