Front pump dilemma - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-11-2013, 06:26 PM Thread Starter
onebadcoastie's Avatar
Quoted: 10 Post(s)
Front pump dilemma
So, as some of you know, I have a spare 5R110W that I plan to build as my "strong" transmission now that I have a few power adders and want to get it out of the way. The reason for wanting to replace the front pump is I don't know the condition of the one in this spare transmission. With a little bit of research I have found a so called aftermarket solution from a company called Level 10. They offer a version of the 5R110W pump that is "modified to supply all the volume the transmission can use at pressures that insure solid clutch lock." They want $498. Level 10 PTS Super Pump
I went to my local dealership and got a price and part number for an OEM pump. My dealer quoted me $732 and showed me on the page there wasn't an overhaul kit for the pump...not sure I believe that. Anyways, I ran the part number on Tousley's page and came up with $482. How do some dealers get away with such a large markup?? That's insane!!!! Tousley OEM pump
My question is, has anyone heard of Level 10, good or bad? I mean at this rate it is a $17 difference between the pump (shipping excluded), but I'm curious about reviews, opinions or other possible options. Any input would be great.
As for the build if any of you are curious, it will consist of a PI torque converter, Elite Diesel HD clutch kit, billet input, billet low/reverse gear, upgraded solenoids and Amsoil's transmission fluid. Should be more than sufficient for what I need. Still up in the air if I want a Mag Hytec pan, Derale pan or just the stock '08 pan.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #2 of 16 Old 07-11-2013, 06:47 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1608 Post(s)
Subscribing to this.... Just picked up a trans to rebuild off CL.
toren302 is offline
post #3 of 16 Old 07-12-2013, 02:51 PM Thread Starter
Quoted: 10 Post(s)
After talking with some folks, I've heard to stay as far away from Level 10 as possible.
Shack
post #4 of 16 Old 07-12-2013, 05:47 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Isn't the pump a gerotor type pump? What do you do the beef that up?
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #5 of 16 Old 07-12-2013, 07:53 PM Thread Starter
Quoted: 10 Post(s)
I think supposedly they manipulate the orifices in there. idk.
Shack
post #6 of 16 Old 07-12-2013, 09:24 PM
05charcoal6.0's Avatar
Send a message via AIM to 05charcoal6.0
Stay far away from level 10. Their only about 45 minutes from me and I've heard nothing but horror stories.
2005 F-350 Extended Cab Short Bed 6.0L
4" Superlift lift
Homemade Traction Bars
MBRP 5" Straightpipe w/ 6" tip
Toyo Open Country mt 35-12.5-20
XD Monster 20x10
Custom Interior
Recon Lights
Train Horns
Banks Intercooler
Volant Intake
RCD Full EGR Delete
SCT-ID Extreme Race - dd
Autometer 4 Gauge Pod
Ultra-lites Boost Pyro Trans Water Fuel
Fuel Press(mounting cup)
Trusted Performance Stage 1 Fuel Lines
Airdog 2
Soon to come:
whatever the wallet can buy
05charcoal6.0 is offline
post #7 of 16 Old 07-12-2013, 09:36 PM Thread Starter
Quoted: 10 Post(s)
That's pretty much what I heard with my other inquiry about the place.
Shack
post #8 of 16 Old 07-13-2013, 12:38 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What clutches and tq converter are you going with?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 16 Old 07-13-2013, 12:46 AM
Like a boss!
Laferty's Avatar
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #10 of 16 Old 07-13-2013, 07:35 AM Thread Starter
Quoted: 10 Post(s)
Precision Industries converter and right now I'm teetering between Elite Diesel's HD kit (which they told me was their kit for guys who tow and what they recommended for my application) or Andy Warren's kit. They both use Raybestos clutches it's just the Elite kit crams 6 clutches in the direct and low/reverse pistons. I gotta call Elite to find out what their final clearance is for the kit before I pull the trigger on it but they also offer military discount too.
Shack
