smoky looney tune? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-11-2013, 04:50 PM Thread Starter
smoky looney tune?
I have a looney wild loaded in my Excursion. I can have cruise set at 55 and if I hit the accelerator to pass someone I get a pretty good cloud of black smoke. I get a good puff when I start the truck and my neighbor swears she can see a faint haze while idling(I can't). Is this about normal?
buddy357 is offline
post #2 of 9 Old 07-11-2013, 05:01 PM
Joeshu1000's Avatar
I've never ran the Looney Wild, but I have ran the Looney tune and it was pretty smokey.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 9 Old 07-11-2013, 05:08 PM
Blue Goose's Avatar
Yep. she will smoke if you stab it, mine wont if I roll into it but when i stick my toe in the turbo she will smoke till the turbo catches up. This is one of the reasons I dont run it very much plus I tow most of the time.
06 KR 250
Blue Goose is offline
post #4 of 9 Old 07-11-2013, 05:17 PM
ngaraiderman's Avatar
Mine is exactly the same. I mostly use the aggressive tow w/Jake and it only smokes a little when I hammer on it.
You can email Vivian and she can tweak it a little for you. She has awesome customer service and usually answers email the same day
ngaraiderman is offline
post #5 of 9 Old 07-11-2013, 05:20 PM Thread Starter
Thanks. I love the power but this is my first tune in the Ex. I was worried I had messed something up with it.
buddy357 is offline
post #6 of 9 Old 07-11-2013, 06:05 PM
Do you have studs?
post #7 of 9 Old 07-11-2013, 06:28 PM Thread Starter
I got studs when I had the head gaskets, oil cooler and egr done. Biggest problem I've had since is that the Sinister coolant filter setup leaks at every joint. I am going to take it out next weekend and try plumbers paste on the threads instead of tape.
I remembered my 7.3 rupturing an injector and flooding a cylinder. That's what worried me.
buddy357 is offline
post #8 of 9 Old 07-12-2013, 06:29 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I ran the Looney too and had the same results. Know this every ounce of fuel she pulls out of it will take away performance, so it's a give and take.
I'm not as critical about smoke on the freeway as I am in town. I'd rather she keep it clean down low and as much as i need when i need it the most.... Passing.
Your results may vary...
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 9 Old 07-12-2013, 08:14 AM
Mine did the same thing. I just used a nut driver instead of a flat bead screw driver and tightened the crap out of them and they stopped dripping.
