Turbo porting question. Need advice. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-11-2013, 01:56 PM Thread Starter
I have my turbo apart and I'm waiting on my mtw billet wheel to come In. While I'm looking at it, I see that there is a lip going around the compressor housing. My question is, would there be any gains to be had by cutting the lip off and smoothing out the area?
Its hard to put into words, so here's some pictures. It's the lip that the screwdriver is pointing to. I've done porting on 4 stroke dirt bike engines, but never turbos. Just curious to see what could happen.
Photobucket Pictures, Images and Photos
Moto2four is offline
post #2 of 11 Old 07-13-2013, 06:06 PM Thread Starter
Well I did it. I didn't take pictures though
With the mtw billet wheel she spools much much faster and pulls harder. Idk how much my porting helped, but I'm happy with it.
post #3 of 11 Old 07-13-2013, 08:21 PM
turbotibbo's Avatar
really ? how did you do it , did it take long?
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #4 of 11 Old 07-14-2013, 06:56 PM Thread Starter
I cut the lip from around the compressor housing. It took about 4 hours. I took a gnarling bit and ground the casting away and then smoothed it all out. I really regret not taking picture of the finished product.
post #5 of 11 Old 07-14-2013, 07:43 PM
Dammit man, pictures!
harrisford is offline
post #6 of 11 Old 07-14-2013, 10:50 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 15 Post(s)
Pictures or it didn't happen
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #7 of 11 Old 07-15-2013, 10:31 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1865 Post(s)
Feedback Score: 4 reviews
OK lol, time to yard it back out and take some pics. Sounds good, but seeing it would be way better
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, KC S2R Ball Bearing Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #8 of 11 Old 07-15-2013, 11:01 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1779 Post(s)
In for when you get pics up.
Sent from AutoGuide.com App
Originally Posted by Heavy_GD View Post
Merged, because lamp.
toren302 is online now
post #9 of 11 Old 07-15-2013, 11:32 AM
While I can't tell the location where you ported it, I would take it apart and address that corrosion to the right of that bolt hole. It looks like a corrosion pit from here. Depending on what it takes to clean it up, you could fill it with epoxy or JB Weld once it's all removed.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #10 of 11 Old 07-16-2013, 11:35 AM
legionxxii's Avatar
To the OP I love your truck I hate chrome with a passion but your truck is so clean and it pulls those wheels off and I hardly ever say I like chrome props man sick truck
Oh and pics or it didnt happen on turbo lol
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
