Detroit Locker vs Detroit Truetrac - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-11-2013, 09:49 AM Thread Starter
DesertSmoker's Avatar
I am getting ready to put gears in my truck so I am thinking of putting a locker in too. I use it to tow a lot and I want better traction in the mountains, in sand and mud especially when yanking trailers around. It needs to work just as well in reverse as it would in drive. Which one would you recommend?
For Sale--2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #2 of 13 Old 07-11-2013, 10:08 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I'd look at the Yukon Grizzly Locker. Slightly cheaper than the Detroit with a MUCH better warranty.
With the Truetrac if you totally loose traction in one wheel you will not have any bias to transfer to the other wheel and you'll be dead in the water so to speak.
I'd do the locker, either the Yukon or the Detroit is you want to absolutely have power to both wheels no matter what.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 13 Old 07-11-2013, 11:39 AM
portcity_gt's Avatar
Quoted: 1535 Post(s)
Ill add, with the trutrac even if one side is off the ground spinning all you have to do is tap the brake and that will engage the worm gears and lock it in to full posi.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 13 Old 07-11-2013, 11:53 AM
HBandy's Avatar
How much does it cost to haves locker installed, generally? I realized how much I want one of these while pulling a guy out of the river yesterday, haha.
HBandy is offline
post #5 of 13 Old 07-11-2013, 12:22 PM
Snake's Avatar
Quoted: 47 Post(s)
TruTrac. Without a question. If you did more four wheeling than driving on pavement, I'd say the Detroit Locker.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 13 Old 07-11-2013, 12:47 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
FWIW, most places advertise tru-trac for tires less than 35"...or that's what I have found but that's not etched in stone. I vote locker.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #7 of 13 Old 07-11-2013, 03:23 PM
I have a True Trac and I'm not that crazy about it. I'll spare you the details, but I wish now that I would have dropped the extra dough then and bought a Detroit Locker. The wheel base, width, and weight of our trucks eliminate a lot of the things normally associated with a locker. We have a Detroit Locker in a short bed half ton on 38s and it's fine on road.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 13 Old 07-11-2013, 03:27 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I've had a Detroit locker in mine for about 7 years with no issues or complaints.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #9 of 13 Old 07-11-2013, 05:06 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1783 Post(s)
I ran a tru trac in my 02 F150 Screw with 38x14.50x15 and it did great. I will go tru trac again for sure.
Originally Posted by Heavy_GD View Post
Merged, because lamp.
toren302 is offline
post #10 of 13 Old 07-11-2013, 05:42 PM Thread Starter
Good info! I will look into the Yukon Grizzly Locker I did not know they made one. So are there any issues with running a locker with 10k loads on or offroad?
