6.0 egr delete - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-10-2013, 10:38 AM Thread Starter
6.0 egr delete
Hey y'all, first day on the site. I have a 2005 and am about to dive in to delete the egr, install new oil cooler, and coolant filter kit from sinister diesel. Any tips? My truck had ARP studs put in sometime before I bought it, any way to tell what size they are so I know how much power I can run safely?
Jay-hawk is offline
post #2 of 14 Old 07-10-2013, 10:58 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Well first Welcome man. Hope to be able to be of some help.
With what you're doing, I would recommend setting aside a Saturday to do. It's pretty easy for the most part but stuff is hard to reach or get to on these motors sometimes and that just eats time.
As far as studs go, there aren't different sizes. There's only different materials and that's gonna be next to impossible to tell I think from just looking at the studs from the top of the motor. I would be more concerned that you actually have studs and if anything, maybe check the torque on them if you do. You can tell if you have studs by looking at the motor around the valve cover and you should see 12 point start nuts that are threaded onto a shaft looking like they clamp the head to the motor. If you see a 6pt hex shape in that spot, then you don't have studs and still have the factory head bolts. If in doubt, post a pic of the passenger side valve cover. I'm sure we would be able to see from the pic if you have them or not. Best of luck.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 14 Old 07-10-2013, 01:59 PM
turbotibbo's Avatar
tips for the egr delete is take your time , lable everything any questions come to the org and ask for help . also youtube has loads of vids and there are tons of build threads on here to look through . I recommend researching a bit befor hand get all your info rteady such as tork specs ect..... its straight forward and can be done by almost any one with basic hand tools good luck
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #4 of 14 Old 07-10-2013, 03:08 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Spend some time cleaning... you really want to be clean and organized when replacing stuff like an oil cooler. Its easy to knock dirt or crud into the valley. Be aware of the injector electrical plugs when pulling the intake manifold as not to break them. Make sure the up pipe V-band flange is absolutely true with the turbo flange before installing and tightening the V-band clamp. Work that first, then tighten the other related components. Last bit... try to find who or where the head studs were installed (oasis report or talk to previous owner). I bought my truck with ARPs installed but I still ended up with blown gaskets 6 months later.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 14 Old 07-10-2013, 05:41 PM Thread Starter
Windrunner, thanks for the welcome. I work at a diesel shop and these motors roll in from time to time, they are a pain to work on but I haven't been real far in to them, just rebuilt a few turbos and replaced some hpo O-rings on the manifold and standpipes. Can I get to all the studs to torque them without lifting the cab up? and whats the spec? i'll check em before I throw a programmer on it. Gottagofast, I bought it from a GM dealer a couple months ago and all they could tell me was it had gaskets, injectors, and new egr cooler done last summer. The dealer was about useless, if you ever have a chance to buy something from coughlin auto in ohio... don't lol Any special tools I might need for this job, or anything I might pick up to make it easier?
Jay-hawk is offline
post #6 of 14 Old 07-10-2013, 06:24 PM
Quoted: 60 Post(s)
Any competent Ford dealer (service dept) should be able to run your VIN and see a repair history. Since you work at a diesel shop, you more than likely have all the tools you'll need. Some of the "hard to reach" fasteners will require extensions and swivels to get at. An air-ratchet makes short work of the rear turbo-mount bolt and V-band clamp (The clamp's threads face the cab from Ford). Speaking of such, you might want to order new V-band clamps in case you bust the old ones. Same with up-pipe hardware.
post #7 of 14 Old 07-20-2013, 04:00 PM Thread Starter
So I just finished the job, new oil cooler, sinister egr delete and coolant filter kit. Started it, let it warm up, checked for leaks, then took her down the road. Before I did the work I would get a light haze of white when I took off, and now its a full cloud. Why would it get worse!? also it doesn't sound right, like a boost leak, rushing air. I torqued every bolt to spec so that really irritates me too... but the engine itself runs smooth at idle. IM stumped. I hope its something that will go away after a couple hundred miles but I doubt it. thanks
Jay-hawk is offline
post #8 of 14 Old 07-20-2013, 05:14 PM
hdodt's Avatar
The turbos in these things don't like to line up with the exhaust pipes much. Check those and all your boots they tear sometimes...good luck.
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #9 of 14 Old 07-20-2013, 06:05 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Getting everything back to being air tight can test your nerves for sure
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 14 Old 08-04-2013, 04:47 PM
dieselforce's Avatar
I am looking at doing a BPD EGR cooler upgrade or a EGR Delete and not sure which way I should go, any recommendations? If I go delete who is the best option and are there any kits that come with the programer and everything needed to perform the job? Thank you in advance
06 F250 XLT Crew Cab 4x4
6.0l Powerstroke Diesel
Suspension Maxx 2" lift/level kit
17x9 KMC XD Series Hoss rims
LT285/70R17 Toyo Open Country AT2 tires
SCT X3 programmer running Innovative Diesel Custom Tunes by Eric
MBRP Performance 4" turbo back muffler exhaust
Cat delete
Carpet Delete
Truxedo Bed Cover
dieselforce is offline
