Hilly areas, towing every weekend need more power - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-10-2013, 06:09 AM Thread Starter
Quoted: 6 Post(s)
Good Morning,
I've got a question here. I have an 05 dually 4.10 that is a manual and need to get more power out of 1st gear without having to go into low. (I hate shifting from low to first gear when on a hill stopped either for traffic or a light) Does anyone have any suggestions? I have the gambit of the bullet proofing procedure: Head Studs, EGR Delete, Blue Spring, New Oil Cooler, Exhaust, FICM, Fuel Pressure Regulator and a few other things I can't think of off the top of my head. Does anyone have any suggestions to improve the response in 1st gear? I regularly tow 10k. I live in western PA and hills and sudden extremely steep grades are all over the place.
First picture is of the truck and trailer, 2nd picture is my son trying to drive it
ID:	136882   Click image for larger version
_____________________
Manual 2005 F350 Dually. 121,xxx Miles.
OEM Gaskets | ARP Head Studs | Blue Spring | AFE Air Intake | Sinister EGR Delete | Amsoil Oil Bypass Filtration | 5" Exhaust | Pyro Meter | EGR Deleted | LiveWire w/ IDP Tow and Vivian's Looney. | SouthBend Double Disk Clutch
2003 Ford F350 SRW | 277,xxx Miles | EGR Deleted
34' Enclosed Cargo Trailer
My website [ARCHOIL, Bulk Ammunition, Body Armor, Medical Supplies, Long Term Food Storage]
EMacsTactical is offline
post #2 of 9 Old 07-10-2013, 06:28 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Have you tried any tunes for some more power?? I would think a nice 50-60hp Tow Tune ought to help get you what you are looking for.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 9 Old 07-10-2013, 06:42 AM Thread Starter
Quoted: 6 Post(s)
I have not done this yet, however have been looking at the livewire
post #4 of 9 Old 07-10-2013, 08:11 AM
Quoted: 101 Post(s)
Feedback Score: 3 reviews
I just got back from towing my new to me trailer to Oregon. I think I was close to 9k. I am running Matt's 8k tow tune. It did great and kept the EGTs under 1200 for most of the trip. That being said I do have an automatic so I don't know if it makes a difference with you having a manual trans.
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #5 of 9 Old 07-10-2013, 04:30 PM
You need something that will give you more torque from idle. I also have a 6 speed, but with 4.30s and I find myself starting in Low sometimes. That being said, maybe a ficm tune ( or a different one) or maybe even a 58v ficm. The dyno sheets I've seen on 58v ficms compared to 48v ones had moved the power curve to a lower rpm. All that being said, when I'm on a hill (from a full stop) I almost always start in low, just for my clutches sake
harrisford is offline
post #6 of 9 Old 07-10-2013, 05:17 PM
smokersteve's Avatar
Quoted: 20 Post(s)
Just an input on a tune and egt's... I towed a 5th wheel 10,100 lbs dry with stock intake, delete pipes, and Innovative diesel STREET tune and my egt's never passed 1,400*F. auto trans.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #7 of 9 Old 07-10-2013, 06:26 PM
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
i have read that the first gear in the manuals were geared to high before... I would not do an atlas 80 or atlas40 ficm tune because your stock exhaust will raise egts too much while towing... the ficm tuns burn fuel longer and have a warning in regards to towing and needing to monitor egts more.
sct tuner with a tow tune would be good start. and a higher flowing exhaust would help. I noticed after muffler delete my turbo spooled up quicker at lower rpms.
If you tow often an egt gauge or pyrometer often called would be a great tool but not much help with 1rst gear issue.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #8 of 9 Old 07-11-2013, 03:07 AM Thread Starter
Quoted: 6 Post(s)
Thanks for the suggestions, I do have a pyro meter and keep my EGTs under 1100 when towing (sometimes takes a bit longer to get there, however it might be worth it in the life of the engine.)
post #9 of 9 Old 07-11-2013, 03:43 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
I would agree on the SCT and a decent tow tune to help you out. A free flowing exhaust can't hurt things either.
RIP Mitch
the Org crew
PGreenSVT is offline
