New turbo - Ford Powerstroke Diesel Forum
post #1 of 64 Old 07-09-2013, 10:29 PM Thread Starter
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
New turbo
Well I keep getting Pm's asking what this power max on steroids in my sig was, so let me just talk about it for a minute. As a lot of people know I've been sold on the power max since I bought mine in 2010. After installing 175/75 injectors I wanted more air to make the haze go away at low speeds like 0-50 mph. So I did some searching on google of different turbo re-builders, contacted a local shop called turbo city and they didn't wanna touch this turbo. So I stumbled across a site called Barder turbo located out on the east coast and asked how can I make my truck run cleaner. So I didn't want to have any down time so I just had James at Barder build me a 68mm off of a brand new power max. He put a slightly larger turbine wheel clipped down to a 70x72.5 a stock power max is 66.5x72.5 somewhere in that ball park. So after a week I get the turbo. Bolt her up and started it up. After start up the truck sounded instantly different. Idle is way smoother and quieter. Took it for a drive on a stock tune/2 street tunes and 3 race tunes. No surge at all. My max egts at wot went from 1440 to 1350 with this turbo change. I did a few wot runs from a 20mph roll and with the power max it would spin from 20-40mph, the Barder turbo with the same 20mph roll spins from 20-55 and at that point I'm at the point of losing control. I haven't noticed any lag driving around the city, if anything there is a split second lag when your in 6th locked going 45mph but that's something that can be fixed in tuning on the trans.
The turbo I recieved was a brand new turbo balanced with a 360 thrust bearing. I'm loving this turbo like you wouldn't believe. The whistle is amazing and the truck hauls major azz. Thought this would be faster than replying to 30pms.
Dyno to come soon on the same dyno the truck laid 581 hp on with the power max.
Max boost I've seen has been 38 with a ebp reading of 37.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #2 of 64 Old 07-09-2013, 10:33 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
What kind of pricing for something like that...if you don't mind my nosy @$$ asking?
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 64 Old 07-09-2013, 10:35 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
A lot cheaper than I expected.
Oliver
ODAWG714 is offline
post #4 of 64 Old 07-10-2013, 05:38 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I'm going to need to know pricing as availability as well, may have a Hybrid W/ Billet For Sale Quick!
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 64 Old 07-10-2013, 05:46 AM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
My turn around was 2 days.
Oliver
ODAWG714 is offline
post #6 of 64 Old 07-10-2013, 05:56 AM
strokin6L's Avatar
Quoted: 3 Post(s)
That sounds awesome man...especially with those injectors. I like that boost/ebp ratio. Does it have a billet compressor wheel?
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #7 of 64 Old 07-10-2013, 06:02 AM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
Ya the ebp was a shocker. I'm gonna try a 71mm with the same mod here soon.
Oliver
ODAWG714 is offline
post #8 of 64 Old 07-10-2013, 06:05 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
that sounds pretty awesome. id imagine they the only added cost would be the new wheel that he drops in. so pmax+350ish
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #9 of 64 Old 07-10-2013, 06:08 AM
snafu!'s Avatar
When are you going to put it back on the dyno?
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #10 of 64 Old 07-10-2013, 06:12 AM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
I'm gonna ship him a turbo to get a compete overhaul. My original power max is 3 years old so I'm gonna have a full re build and a larger thrust installed and balance it so its like a brand new turbo. It may be laggy but may not be due to my added air flow. Well see. If I can get my wot egts down to the 1200s I'd be stoked.
Oliver
ODAWG714 is offline
