turbo blanket? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 07-09-2013, 04:23 PM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
turbo blanket?
Found that there's a turbo blanket for the 6L. Do you guys think that it'll help with anything... spooolup and keeping under hood temps down or anything else good?
http://item.mobileweb.ebay.com/viewi...id=11202993693
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 22 Old 07-09-2013, 04:36 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Search Feature at the top of the page will reveal this was recently discussed with a lot of different ideas as to why or why not.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 22 Old 07-09-2013, 04:37 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I think it'll be good at holding moisture to the cast iron and rust the hell out of the housing unless it is ceramic coated. I'll just use my experience with wrapped up/Y-pipes. I wrapped those and didn't notice any difference. I do think that it will possibly help with under hood temps. However though, like I said, I would do it in conjuction with a ceramic coated housing.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 22 Old 07-09-2013, 05:15 PM
04cr450's Avatar
I would ceramic coat your up-pipes and wrap them with 2000 degree heat wrap.... I noticed a huge difference in temps under the hood. Well worth it, glad I did it.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 22 Old 07-09-2013, 05:23 PM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
My up pipes are already wrapped...not coated tho
post #6 of 22 Old 07-09-2013, 05:24 PM
scparrish's Avatar
Quoted: 85 Post(s)
Feedback Score: 3 reviews
I have been thinking about ceramic coating the exhaust housing
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #7 of 22 Old 07-10-2013, 06:24 AM
I have a turbo blanket and noticed faster spool up not a lot but it was less laggy... I love mine
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #8 of 22 Old 07-10-2013, 06:41 AM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
How well did it fit around the housing? Where'd you get yours
post #9 of 22 Old 07-10-2013, 08:31 AM
It fit around it good was a pain I the *** getting it on but works great and has helped keep some heat down in my engine bay. I don't remember exactly who I purchased it from but it was a thread on this site that I got the info from.
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #10 of 22 Old 07-10-2013, 08:42 AM
BACKYARDIGAN
Quoted: 4 Post(s)
The blanket you posted link to Chris, looks pretty sweet.
Nate
