SCT tuner MPG - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-09-2013, 11:28 AM Thread Starter
SCT tuner MPG
I don't how to combine the table with the text, so click on link to see my results of the SCT with custom and canned tunes.
2007 F-250,SD,PSD,King Ranch with chrome,CC,SB,SRW,3.73,Auto,4X4,Dark Copper,Camper Package,ESOF,6-Disc CD, Advance Tonneau Cover, Towing a Carriage Cameo XLi 32RLS 5er using SCT 3015, with Edge Insight CTS monitoring.
jdrmmr is offline
post #2 of 3 Old 07-09-2013, 12:26 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
I appreciate the effort but my truck wont settle into a consistent MPG range until I have a tank or two through it - 5 miles wont give you an accurate test, imo.
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #3 of 3 Old 07-09-2013, 12:40 PM Thread Starter
I zero mine at every fill up. I fill to the top of each tank (no foam) and then figure my mileage. I have one spot in my book for the liemeter and one spot for hand calculations. When I fill up this time I wonít be able to check my meter against my hand calculations because of all the zeroing I did for my off the wall test today.
I know this wasnít the best test. But I had all the tunes and I knew I was getting different mileage so I decided to see which one was doing what I think is the best for me. They all had the same about of time to give me a pretty good indication. This is not the mileage I will see. It is I hope an indication of which one will give me better mileage.
I wish I could see that mileage over 70 gallons of fuel. Ainít gonna happen.
jdrmmr is offline
