Should I get an edge insight cts? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-09-2013, 12:12 PM Thread Starter
JOEDOG223's Avatar
My truck is completely stock and I've been hearing and reading how I should get a monitor. Is this a good idea? Is the insight cts a good one?
I'm also wanting to get a sct tuner. Will these two work okay together?
Any input is appreciated. Thanks.
JOEDOG223 is offline
post #2 of 18 Old 07-09-2013, 12:16 PM
ULM2008's Avatar
Yes. Best 1st addition you could install. I got the cs and shows you everything you need. An edge accessory you should also consider is the egt probe. Cs or cts is a great investment for watching vital temps and possible pre mature failure
2005 F-250 XLT Ext. cab SB 6.0 4x4
SCT X3 custom tuned by Quick Tricks
Edge insight CS with EGT
Dieselsite Coolant filter
Pmax
Sinister Deleted
RR boots
STC fitting
Banjo and B/Spring
58V Quick Tricks
MBRP
Nitto
Firestone Ride Rite
Whelen strobe LEDs
Rigid D2's
ICON shocks, coils, blocks
RanchHand R Bumper
ULM2008 is offline
post #3 of 18 Old 07-09-2013, 01:36 PM
Agreed. It allows you to see problems coming rather than fixing them once something bad happens. First thing you should buy, IMO.
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
post #4 of 18 Old 07-09-2013, 02:18 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
The monitor should be the first thing you add to the truck. Shame to let the cost of a tuner keep you from buying the parts you need to keep the truck on the road. Check my threads in my sig for a lot of what you need to know and watch out for with the 6.0L.
Any questions, just ask.
As for it working with a tuner, as long as you use a flash tuner like the SCT, you wont have any issues.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 18 Old 07-09-2013, 02:24 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
YES YES YES YES YES YES YES.......and YES!!!! Basicly what you have now is a computer without a monitor,the computer will run but you cant see what it is doing. So you can just keep running it,blindly with the hope all is well or you can get a monitor and get pro active.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 18 Old 07-09-2013, 02:30 PM
ngaraiderman's Avatar
X2 what he said
ngaraiderman is offline
post #7 of 18 Old 07-09-2013, 02:32 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i'd get a livewire TS 5015 and 3 custom tunes and don't put the tunes on until you have bullet proofing done
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #8 of 18 Old 07-09-2013, 03:44 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Their are also other monitors a available that cost less. DashBoss for iOS devices (iPad/Itouch/iPhone). Torque for android based phone/tablets. ScangaugeII.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 18 Old 07-09-2013, 03:48 PM
kcoyner's Avatar
Quoted: 55 Post(s)
I love my EDGE!!
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #10 of 18 Old 07-09-2013, 04:51 PM
dang, beat me to it. LOL
OP yes get a monitor. best mod in my book. Those factory gauges just dont cut it on these trucks like they do on fiestas or something like that. I believe it is imperative that you are able to see what is going on so you can catch potential problems before they leave you stranded.
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
