Autometer HPOP Gauge install..... HELP! - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 24 Old 07-08-2013, 07:53 AM Thread Starter
I need to find where the HPOP/ICP sending unit is so I can tap the two wires for the gauge input.
The truck is a 2004 6.0. F350 Automatic.
I called Autometer and he said it should be on the pass side valve cover. Well I cant find it and have looked everywhere and NO Dark Blue with green tracer and grey with red tracer.
A picture would be helpful.
Thanks!
jonw is offline
post #2 of 24 Old 07-08-2013, 07:56 AM
dxusmc's Avatar
well..If you have an early 04..it might be under the turbo near the IPR...otherwise if its on your pass side valve cover, its right above the glow plug module..almost directly underneath the hot side CAC tube. Don't have a picture for ya..but if you're not seeing it there, chances are you have an early build..and its buried in the back. Sorry for the bad news
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 24 Old 07-08-2013, 08:11 AM Thread Starter
Build date (according to door sticker) 7/03.......................
jonw is offline
post #4 of 24 Old 07-08-2013, 08:51 AM
Snake's Avatar
Quoted: 46 Post(s)
The sender should be behind the turbo for that build date.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 24 Old 02-20-2014, 01:47 PM
BUMP!
Will this gauge read the actual psi, not the skewed number that is displayed when you have a custom tune?
http://www.summitracing.com/parts/atm-4396/overview/
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 24 Old 02-20-2014, 02:25 PM
portcity_gt's Avatar
Quoted: 1213 Post(s)
If it reads off tye sender then yes it will read correct, the "tricked" reading should only come from tye obdII port.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
The Following User Says Thank You to portcity_gt For This Useful Post:
Karls03 (02-20-2014)
post #7 of 24 Old 02-20-2014, 02:57 PM
I was thinking it would read that way.
The next obvious question (to me anyway) is: will a tuned 6.0 hpop going to generate in excess of 4000 psi?
Karl and his 2003 Souper Doody
Karls03 is offline
post #8 of 24 Old 02-20-2014, 04:08 PM
snafu!'s Avatar
Yes it should hit 4000 psi if everything is healthy.
I use my edge CTS to monitor ICP voltage and it is accurate while tuned, I hold 4.8 to 4.6v at wot with 175s
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #9 of 24 Old 02-20-2014, 05:08 PM
Hmmm, I'm going to have to research if the Scan Gauge II does ICP voltage. It does ICP pressure, but that's useless when you're running a tune. Why spend $150 on something I already have the capability to monitor.
Karls03 is offline
post #10 of 24 Old 02-20-2014, 05:26 PM
strokin6L's Avatar
Quoted: 3 Post(s)
wrong. It's all in the tuning. I have a HPOP gauge and certain tuning will give an incorrect reading even when you are getting it directly from the sensor. I run Eric's tuning and my HPOP gauge would never read over 1500psi when tuned. Turn it back to stock...it'll read normal. Voltage will also read incorrectly. Now, since I installed the stage 3 68mm vgt back in September...eric rewrote my tunes and now ICP psi and voltage will read normal when tuned. The tuner can mess with/fool with the icp to read incorrectly even tho the reading is coming directly from the sensor itself. I have an early '04 with the sensor in the HPOP cover under the turbo. I used Strictly Diesel's HPOP pigtail http://www.strictlydiesel.com/p-2657...l-pigtail.aspx makes it a lot easier than cutting and splicing the factory harness. Just plug n play.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
