190cc Injectors and ICP - Need your input - Ford Powerstroke Diesel Forum
post #1 of 58 Old 07-08-2013, 06:01 AM Thread Starter
twoicebergs's Avatar
Quoted: 43 Post(s)
If you had followed a few posts of mine I noticed I was dropping ICP as the EOT got up to operating temperature. I ended up changing out pretty much all of the HPO system and ended up with the same result. When cold I can get 4100 psi but when the oil is >195* the max sustained ICP is around 3000 psi.
There have been a number of posts by others, on a number of sites, saying they are seeing lower pressure and ICP volts, but often the result is masked by the tune and the monitor's capability. I want to quantify the issue to known voltage or pressure drop with larger injectors. So, those with 190-225cc injectors running a max tune (2.7ms or close to it) please chime in with your observations. Mine are 190/50 and 186/75 open port injectors. They both drop ICP when the tune gets over about 2.2ms when warm. I am wondering if the open port and the 205ish stroke are robbing too much capacity from the HPOP?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 58 Old 07-08-2013, 06:52 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I'm in the same boat. Its been this way for me since I started monitoring ICP. When tuned after oil is up to temp my ICP will only read like 1520-1550 max...voltage will be low also. Talked to Eric at ID numerous times about my readings...and was told that what I'm seeing when tuned is perfectly normal. However before truck gets up to operating temp when tuned...ICP can go a lot alot higher. Again Eric told me this is normal cause as the oil heats up it will thin out. Now, when I turn the truck back to stock...ICP will get over 3600 no problem and I've seen voltage as high as 4.7. Mentioned the reading differences to Eric when tuned and when stock and again was told that its normal for what I'm seeing. And getting the ICP pressure reading right from my ICP sensor. My injectors are 190/75's from Full Force. I plan on doing some stuff to the truck this next spring...and one thing will be having the hpop system checked over just to rule out any leakage.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 58 Old 07-08-2013, 07:36 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
While I haven't actually monitored or checked my ICP pressure or voltage, I have to say that if you are seeing a drop in ICP when warm, then that to me means that you are either getting slip by in your HPOP and/or your HPOP is too weak for the task of supplying your injectors. I could see the possible tuning thing skewing the ICP reading but that would be across the board. That would not be the reason why you read 4100 psi at 180F and 3300 psi at 200F. It's like reading LPO pressure. Everytime I start my truck, I see oil pressure around 75 psi but the oil is at like 75F too, but when I get up to my operating temp of 209F, I see 52-55psi. The oil is thick when it is cold so the resistance created when trying to increase flow, jacks pressure up in comparison to when it is cold.
This is why I am wanting to put a dual HPOP setup on my truck and I don't have any real plans to go bigger than my 190/100s. Adrian has the dual HPOP setup on his and he is seeing 4.9v of ICP at WOT and hot.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 58 Old 07-08-2013, 07:58 AM
05f250harley's Avatar
Subscribed because I plan on getting 190/100 injectors
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #5 of 58 Old 07-08-2013, 08:07 AM
Just out of curiousity, what oil are you guys running?
harrisford is offline
post #6 of 58 Old 07-08-2013, 08:19 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Amsoil 5w40
Nate
post #7 of 58 Old 07-08-2013, 10:03 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Either 5w40 amsoil or valvoline
post #8 of 58 Old 07-08-2013, 10:34 AM
So are you guys thinking that maybe a heavier weight oil will help hold ICP?
post #9 of 58 Old 07-08-2013, 11:24 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Chris/Frank...have either of you tuned your trucks back to stock and measured the readings from cold to hot and compared the tuned readings? I was always under the impression the tune writers fudge the icp for whatever readings???
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #10 of 58 Old 07-08-2013, 11:52 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Yes I have I mentioned that in my post. Under stock tuning my ICP pressure and voltage readings are normal. Eric told me that everything reads the way it does when tuned is because of the tuning.
