Fuel pressure - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-07-2013, 11:30 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Fuel pressure
Was thumbing through some old post but couldn't seem to find something as a kit with the fitting gauge and sending unit. Also does the edge CTS run fuel pressure? If not is there a link I can find all the goodies for a gauge?
04fording is offline
post #2 of 3 Old 07-08-2013, 06:42 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
As far as I know, you are correct, no kits are together. I had posted a number of links in the past, but as time moves on, the product offering links change as well. There is nothing special about the parts involved or even how to do it. A simple 100psi pressure transducer from eBay (over 1086 sold so far. $28), a 12x1.5M - 1/8"NPTF fitting to slip into the fuel test port ($6 available from many locations), and a 45* or 90* elbow ($3). Some have run hoses in fear of vibration issues, but I didn't since most of the other engine pressure transducers are mounted right on the engine and they do their job quite well. You will need to tap into a power source (usually 5v) and attach it to one of your monitors analog inputs. Your CTS manual should tell you how many inputs you have and what voltage is supported.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 07-08-2013, 08:19 AM
Chatham036's Avatar
Quoted: 131 Post(s)
The method I went with was to get the insight, universal input kit, and pressure sensor all from edge.
as the previous poster mentioned, vibration can cause an issue. Strictly diesel makes a kit with all adapters and hose to remote locate the sensor
Product can be found at
http://www.strictlydiesel.com/p-2671...e-adapter.aspx
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
