I knew it was a matter of time!!! - Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 60 Old 07-07-2013, 07:39 PM Thread Starter
madpowerstroke's Avatar
So I noticed that a turbo shop is now building turbos and are same as the ones I have spent so much to research and develop. I knew it was going to happen and that is why I have not stopped to develop better turbos for the 6.0. They are copying ideas just like all the other vendors had have their ideas copied. Intakes, injectors, tuning and so on. I wish them and anyone else luck to build the same things as me. I learned a little late on stage 1 and Hybrid but not the rest, what do I mean? well I had the compressor wheels manufactured by a company in China that doesn't care about exclusive manufacturing so other companies and shops can get the same wheels to make same product.
I have stopped them building any of my wheels of new sizes and design and found one that will grant me exclusive rights. I have a new turbo coming out the and will be a 66mm VGT, spent a lot of money and research to get this turbo to run 175 and 190 injectors. I also have a new stage 4 coming that will have the exclusive compressor wheel that is bigger then the stage 4 right now and will be a monster.
I have also seen that there are shops out there trying the gt40 wheel in their turbos to make them into a clone of my stage 3 and 4. Good luck with that one, a standard gt40 wheel won't work and will melt anything above 1700 degrees, there is only one gt40 wheel that will handle 2000+ degrees and nitrous all day long. Actually soon to be two gt40 wheels, one that I will be having custom made again bigger then the gt40 and stronger that will be exclusive. I maybe new to building turbos but I did all my homework, and trail and errors. I have also found out a lot about what makes the 6.0 powerstroke tick and what combos work the best.
I will be spreading out to the 6.4 and have wheels being made as you read this again keeping exclusive rights, why should I pay for development just to have someone buy it after words and sell it. I will also be moving to 6.7, later and even some other brands of diesel trucks.
I will continue to research and develop the best turbo I can build at a fair price, and if some other want to copy at least acknowledge that I was the guy that started it. I welcome the competition and the best complaint is being copied, hopefully the end result is just more options for turbos out there. I do think something is rather funny is that some of the haters are jumping on their bandwagon.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 60 Old 07-07-2013, 07:57 PM
BucOff's Avatar
Adrian, you had to know it would happen. It's too easy for others to ride the coattails of hard working folk, only to try and make a buck off of others hard work. Keep up the great work and keep on spooling...
BucOff (GPDA Member)
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #3 of 60 Old 07-07-2013, 08:08 PM
They can make whatever they want, it's the service at MTW that keeps people coming back. Any time someone asks for my turbo inputs for a 6.0, my first answer is MTW!
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 60 Old 07-07-2013, 11:54 PM Thread Starter
Thanks guys, I will do what I can to keep up the products and customer service.
post #5 of 60 Old 07-08-2013, 04:19 AM
Pwraddr's Avatar
Quoted: 3 Post(s)
Sad reality is the exclusive rights won't help you. The competition will buy your turbo, disassemble, and have someone copy what's inside.
I wouldn't spend anytime on exclusive rights, just do your best on the service end and the rest is going to happen no matter how hard you try.
Pwraddr is offline
post #6 of 60 Old 07-08-2013, 05:38 AM
Adrian, you need to go mainstream. Maybe offer a turbo to Diesel Power magazine for their 6.0 project
harrisford is offline
post #7 of 60 Old 07-08-2013, 12:12 PM
BucOff's Avatar
Good idea...
439 rwhp/863 lb/ft.
BucOff is offline
post #8 of 60 Old 07-08-2013, 12:24 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1119 Post(s)
Feedback Score: 6 reviews
I was wondering when someone was going to start copying your mad skills Adrian. Keep at it man!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #9 of 60 Old 07-08-2013, 02:12 PM
You def need to market a bit more, cause dummies with monies make the world go round and your biz does not run on love. That said, keep up the good work, cause karma can be better than credit!
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #10 of 60 Old 07-08-2013, 02:37 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Actually diesel power did ask Adrian to give a turbo to their project 6.0 build. But I'll let Adrian comment on that if he wants.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
Closed Thread
