6.0 turbo machining - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-06-2013, 06:35 PM Thread Starter
6.0 turbo machining
Has anyone machined the stock housing on our turbos to fit a bigger wheel? How much can you machine them? Could you take them big enough to fit a powermax wheel?
harrisford is offline
post #2 of 5 Old 07-06-2013, 11:12 PM
1fastTRX's Avatar
You have to machine the backplate as well, but yes you can punch it out to fit a powermax compressor wheel (63.5mm x 88mm).
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #3 of 5 Old 07-07-2013, 05:25 AM
madpowerstroke's Avatar
Stock housing will accept up to a 64.7mm not much left after that, and as stated the backing plate needs machining also. Stock backing plate is 82mm and powermax wheel is 88mm.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #4 of 5 Old 07-07-2013, 04:31 PM Thread Starter
Adrian, whats your pricing on the billet powermax wheels?
post #5 of 5 Old 07-07-2013, 04:45 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
$250 with Free Shipping. PM me for more details.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
