FAN CLUTCH QUESTIONS..... - Ford Powerstroke Diesel Forum
post #1 of 33 Old 07-06-2013, 02:37 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
First off hope everybody had a great 4th of July.
Ive got a nagging issue with what I think is my fan clutch. Under heavy load while the fan is engaged I have a loud squealing coming from the fan area. I say this because the volume and pitch changes as the volume of the air from the fan goes up and down. (as the fan rpm changes) This squeal to me sounds like possible metal to metal trying to lock up?? The fan does come on and does work,but with a squeal. And this bugs me.....
So here is the questions-
1) what might you think this squeal is?
2) when a fan clutch fails does it fail into a free spinning (neutral) or does it go into a always on no matter if needed or not.
3)Im guessing that the "special package" fan clutch for the ambulance or camper package is the heavy duty. But is it needed. And fyi no Im not hauling a 40k lbs 5th wheel across Airizona in August with a heavy head wind. Its mostly a D/D that hauls my bumper pull around and a load of horse hay a few times a year. And when you figure the special package clutch is twice the price, the Dorman 622-002 @ $138 looks pretty good....(partsgeek.com)
Thanks in advance
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 33 Old 07-06-2013, 02:56 PM
rr06psd's Avatar
I might be the belt tensioner. I just had studs put on mine. I put in new tensioner, idler pulleys, snow plow clutch and belt as a preventive maintenance while it was apart.
You are welcome to my standard clutch if you like. It was running fine when replaced. I got the snow plow from dieselfiltersonline $258.00 .
A side note. Temps are more where I like to see them. Only used the fan switch twice on recent trip.
2006 F-250 Lariat FX4 CCSB
BPD EGR Cooler
BPD Oil with cold Weather
Amsoil Bypass
Baldwin Coolant Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Silverline 4'' turbo back
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #3 of 33 Old 07-06-2013, 03:28 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I gotta say your awesome! This is the second time you have had extra parts and your "WELCOME" mat out......
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 33 Old 07-06-2013, 04:09 PM
rr06psd's Avatar
Hey you were one of the guys that made a offer of help when I was passing threw your town and I don't forget that stuff.
Like I said your welcome to all those parts if you want. I had no noise on my tensioner when it was pulled off so I believe the spring is good. There is a thread that lists the part numbers to replace the bearings on the idlers and tensioner. I'll send you the goodies and you can replace bearings and save some coin. I would recommend getting a OEM clutch though.
BPD EGR Cooler
Amsoil Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #5 of 33 Old 07-06-2013, 04:30 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Well I appreciate it. But while I got ya Ill let me ask you, can you monitor the fan cycle %? with the edge? Im lookin but don't see it.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 33 Old 07-06-2013, 04:33 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I guess the first thing I need to know is what would a healthy fan do. With mine, I can move it back and forth (while not running) and it does have drag. Then upon start up it kicks in with the motor. When I flip the manual control I can hear it come on harder. So I assume this is the duty cycle.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 33 Old 07-06-2013, 04:42 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Might not be the fan clutch. I had my fan clutch fail on me a long time ago. When it fails you aren't able to start the truck. When mine went...I had to have it towed to the dealer where by buddy works. He unplugged the fan and truck started right up. Guess its some sort of safety thing...that if the electric fan clutch fails...it doesn't allow you to start the truck... this way you won't risk the chance of it overheating.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #8 of 33 Old 07-06-2013, 04:43 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
well heck that's good to know right there....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 33 Old 07-06-2013, 04:50 PM
rr06psd's Avatar
I can't see fan % with my old style edge insight but I can with ae. I never heard my clutch running at start up or running until one of two conditions. Driving under 45 mph and coolant temp hit 208 fan would come on loud for a few seconds or I turn on manual switch. My truck still acts the same with plow clutch however all temps are lower at all speeds so it is moving more air at all speeds.
BPD EGR Cooler
Amsoil Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #10 of 33 Old 07-06-2013, 04:53 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Yeah I was going out to my truck one morning to go to work...went to start the truck and ait didn't even crank....just nothing. That was weird cause it acted like the batteries were deader than dead, but I new they weren't. Tried it again and still nothing...I was totally stumped and couldn't figure out what was going on. If I knew that's all I had to do to start it I would've just in plugged it. Really wouldn't have been worried about it over hearing cause work was only 10 miles away.
