Finally fix my egt probe issue - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-06-2013, 08:17 AM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
Ok guys so I went to put in my edge easy egt probe I drilled and tapped the hole like the instructions say. When I did that I put the probe in and it hit the other end of the manifold so after driving around all day and speaking to some forum members last night came up with this a 1/4-14 npt male to 1/8-27 npt female fitting to make it work I took the same 1/8 hope I drilled and drilled it to a 7/16 hole then tapped it again with a 1/4 not tap. Here are some pics thanks alot for the help guys
1/8 hole
Egt probe hitting other side of manifold
Edge fitting into 1/4-1/8 adapter
1/4 tapped hole
Both fitting test
Clearance on egt probe had to make sure the fitting wouldn't cover the probe
Installed and finished
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #2 of 13 Old 07-06-2013, 08:22 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 953 Post(s)
Feedback Score: 6 reviews
Good stuff man, glad you got it all squared away.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 13 Old 07-06-2013, 08:23 AM Thread Starter
usnavyad's Avatar
Yeah it was quite the pain
GPDA's other shawn
usnavyad is offline
post #4 of 13 Old 07-07-2013, 01:26 PM
Now update your sig....lol
2005 F350 CCLB 6.0L
MBRP 4" with 5" tip
Fordfanatic05 is offline
post #5 of 13 Old 07-07-2013, 01:29 PM Thread Starter
usnavyad's Avatar
True that lmao
GPDA's other shawn
usnavyad is offline
post #6 of 13 Old 07-07-2013, 07:55 PM
Great info, awesome documentation, and beautiful truck! I'm getting ready to install my EGT sensor in the next week or so. Is the problem you encountered a common one? How much do I need to worry about my sensor hitting the back of the exhaust manifold? Any/all help is appreciated. Thanks again!
ROB
2006 F350 Lariat CC LB FX4 Dually Auto 4.10
MODS:
Edge Insight CTS
SCT X4 Quicktricks Custom Tunes
KC Stage 2
MBRP 4" Turboback Straightpipe Exhaust
BPD 58v FICM, PHP Atlas 80 Tune
IPR High Flow Coolant Filter
ARP Head Studs & EGR Delete
Blue Spring
DC Power 250 Amp Alt & Big 3 Upgrade
Interstate Mega-Tron Plus 65 Batteries
42" LED Light Bar
Fleetrite ELC Coolant
IPR Remote Oil Cooler
2008 Tow Mirrors
20" Meyhem Monstir Chrome Wheels
SelahPSD is offline
post #7 of 13 Old 07-07-2013, 08:03 PM
KCCO!!
kells17's Avatar
Now we can plan our next meet!
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #8 of 13 Old 07-07-2013, 08:09 PM
Like a boss!
Laferty's Avatar
Why so close to cylinder 2 (?) on the manifold? Shouldn't it be at the other end to get the collective temp from all the cylinders? And it looks like you have some fluid leaking down your block. Lol.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #9 of 13 Old 07-07-2013, 08:10 PM
That certainly looks cleaner than plugging the hole and boring another one.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #10 of 13 Old 07-07-2013, 08:10 PM
Like a boss!
Laferty's Avatar
Why? So you can bail out again?
2006 CCLB
Laferty is offline
