Going to attempt at installing a 6.4 intake manifold - Ford Powerstroke Diesel Forum
post #1 of 112 Old 07-06-2013, 01:24 AM Thread Starter
I've seen others cutting up their stock 6.0 manifolds and hogging them out. Lots of welding, labor, more labor if you cut out the EGR section, chance of warping/leaking. Also I'm sure chances are slim with lock tite but I'd be nervous with the manifold bolted down from the inside..if a bolt comes loose it will be ingested by the engine.
With that said I'm going to take on the challenge (alternator mounting, possible sensor bung relocation and tab cut offs) of installing a 6.4 manifold and document it. I plan to do some changes to the manifold to get it to flow close to a ported one and address the lack of rear cylinder air flow that plagues both 6.4 and 6.0 manifolds.
Just ordered the manifold and will take pics as I progress. Thanks
makaveli200369 is offline
post #2 of 112 Old 07-06-2013, 01:34 AM
KCCO!!
kells17's Avatar
Looking forward to this one. Sub'd.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 112 Old 07-06-2013, 03:24 AM
ThomasvillePavers's Avatar
Sub'd as well
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #4 of 112 Old 07-06-2013, 04:03 AM
Are you done yet ?
4realestate is offline
post #5 of 112 Old 07-06-2013, 06:30 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Don't forget about the intake elbow, IC piping, and serpentine belt.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 112 Old 07-06-2013, 06:43 AM
mustangmike6996's Avatar
yea... im subbing to this
mustangmike6996 is offline
post #7 of 112 Old 07-06-2013, 09:21 AM Thread Starter
Originally Posted by 4realestate View Post
Are you done yet ?
lol I would be if the intake was here. I wish I would of had it over this 4th of July weekend. I have a full bottle of argon and fresh stock of filler rods..my Miller SyncroWave wants to get to work!
post #8 of 112 Old 07-06-2013, 09:33 AM Thread Starter
Also the dent in that intake needs to be removed.
It's going to look so much cleaner without the EGR section the 6.0 has
post #9 of 112 Old 07-06-2013, 02:26 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 112 Old 07-07-2013, 04:54 AM
madpowerstroke's Avatar
I have done this mod as well as Nate. We both made brackets for the 6.4 intake for alternator, but you could use a alternator bracket for a dual system. Both Nate and I also machined the post on the inner section of runner to free up flow, and both of us used two bolt system. You will also have to do something with the coolant passage which I taped and installed pipe plug, but you could install a freeze plug there. I went and tee into my heater line to route the coolant from the EGR delete. Tuscany was running Nate's manifold and I'm running the one I made, both of us noticed a 150-200 degree differance in EGTS at cruise. I think that it works better then the 6.0 ported intake, since I tried both, but that was on my truck could be different on another truck. Here's some pictures of manifold before I installed it, have fun with your mod.
I welded the intake eblow on the intake also, and will have to cut and weld the cac pipe from intercooler to intake elbow.
ID:	135394   Click image for larger version
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
