Building a external oil ffilter and cooler - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-05-2013, 07:16 PM Thread Starter
it's prob been written up a million times will be posting parts list for anyone else who wants to make a kit over the next few weeks but to start
i found billet pre tapped oil filter caps on ebay for 60 bucks
2005 F350 ccsb way to many things to list
mderrickson216 is offline
post #2 of 21 Old 07-05-2013, 07:31 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Are you referring to full flow or a bypass unit??
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 21 Old 07-05-2013, 07:39 PM Thread Starter
Bypass kit.
post #4 of 21 Old 07-05-2013, 07:44 PM
ZMANN's Avatar
Quoted: 1354 Post(s)
if you DIY or piece meal a kit do not forget a flow restriction
or you may overwhelm the bypass and rob oil from the motor
the cooler ? I don't think it will contribute any benefits to an OEM system that if working properly has no issue with oil temps
they call Me
Buzz Kill
LOL
We Miss you Ronnie
ZMANN is offline
post #5 of 21 Old 07-05-2013, 07:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Oil restriction hole depends if your going to use a "full flow" filter like the Amsoil EaBP series or a "bypass" filter that has restricter hole built into the filter.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 21 Old 07-05-2013, 07:51 PM
kdogg85's Avatar
Hope it works out for you.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #7 of 21 Old 07-05-2013, 07:53 PM
ZMANN's Avatar
well I assume you wouldn't pull full flow system from the OEM oil filter and dump it back to a oil fill or drain plug like you would with a like you would with a restricted flow Bypass
otherwise it seems you would seriously compromise the OEM oiling system
also My bypass filter does not have a restrictor it is inline and why I mentioned it
We Miss you Ronnie
ZMANN is offline
post #8 of 21 Old 07-05-2013, 07:54 PM
Powerstroke Techie
Lilpooh's Avatar
As for adding a cooler to the bypass oil lines, I've heard of two people doing this. Only one reported a EOT drop, but no evidence was posted to confirm his findings.
Lilpooh is offline
post #9 of 21 Old 07-05-2013, 07:57 PM
Powerstroke Techie
Lilpooh's Avatar
Your right, but some people think that using a Amsoil EaBP series filter has a built in restricter hole, it don't. The EaBP series is a full flow bypass filter that you need to make a restricter hole somewhere in the bypass head or lines.
Lilpooh is offline
post #10 of 21 Old 07-05-2013, 07:59 PM
Powerstroke Techie
Lilpooh's Avatar
Mderrickson, what size threads are on the filter head, that you will be using?
Lilpooh is offline
