So I installed my pyro today - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-05-2013, 03:24 PM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
I installed my egt gauge I think the tip is hitting the other side of the manifold I hope it don't effect it to much
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #2 of 6 Old 07-05-2013, 03:27 PM
ZMANN's Avatar
Quoted: 1350 Post(s)
if it didn't damage it i think you'll be fine
I went a little more to the bottom so hitting the side wasn't an issue
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 07-05-2013, 03:30 PM Thread Starter
usnavyad's Avatar
No it won't damage worried bout the readings
GPDA's other shawn
usnavyad is offline
post #4 of 6 Old 07-05-2013, 03:32 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 834 Post(s)
Feedback Score: 6 reviews
If you are worried about the reading, couldn't you just back it out a little, but not too much where it might come loose and fall out?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #5 of 6 Old 07-05-2013, 03:39 PM Thread Starter
usnavyad's Avatar
If only it was that easy lmao I only got like 3 threads on the nut
GPDA's other shawn
usnavyad is offline
post #6 of 6 Old 07-05-2013, 04:41 PM Thread Starter
usnavyad's Avatar
I'm going to try and back it out
GPDA's other shawn
usnavyad is offline
