CounterAct Balancing Beads or ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-03-2013, 06:01 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Traditional Lead taped to the Wheel?
Having a shimmy 55+ really noticeable at 70 Discount Tires can't get out of my MT's Baja ATZ 37's
They finally gave me my money back and said .... 4 Wheel Parts
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 8 Old 07-03-2013, 09:07 PM
new2deisel's Avatar
I've been running these for over 4yrs now without any problems and I am bad about rotating(which I'm probably do for).
Tire Balancing Products
new2deisel is offline
post #3 of 8 Old 07-03-2013, 10:10 PM
I've run beads in lots of tires for the past couple years. Seem to be perfect every time
harrisford is offline
post #4 of 8 Old 07-03-2013, 11:25 PM
adamread's Avatar
I run the Centramatics on my 06 with 35" Cooper Discoverer S/T's, and it rides smoother than it did on 32" Wrangler Silent Armor Pro's. They're about $200 for the set of 4.
2006 F250 CCSB - Full PMF Suspension (3.5" 3-Link, 5.5" Traction Blocks, Drag Link, Track Bar & Steering Stabilizer) Bilstein 5100s, Hellwig's F+R, Centramatics, 20" Harleys, 35" Cooper Disco STTs, Nuc Bypass, Marine Charger, DDEC60 Block Heater, ARB w/ HID Hellas, BPD Water Pump, 5" MBRP Straight, SCT-X3 w/ IDP, H11's w/ OEM Gaskets
Dead in Water - Blew Turbo / IPR
adamread is offline
post #5 of 8 Old 07-04-2013, 06:05 AM Thread Starter
Quoted: 2 Post(s)
Thanks, a search turned up enough positive information to go for it.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 8 Old 07-04-2013, 08:02 AM
Quoted: 2 Post(s)
D
Keep us updated, ive been debating on using beads in my dually tires. On another note a friend of mine had a shimmy on his F350 at 45ish then again around 70. He had the driveshaft balanced and said all is well now.
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #7 of 8 Old 07-04-2013, 08:20 AM Thread Starter
Quoted: 2 Post(s)
Mine was almost perfect, so i rotated and balanced... went to Hail.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 8 Old 07-04-2013, 08:28 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I have 33x12.5x18 MT atz's. Got almost 20k on them. They have the tape weights for balancing. I rotate them every 4k mikes cause that's all I put on my truck each year. But my buddy has those beads and loves them...work much better with better results than the weights. I'm gonna use the beads next. Mine need to be rebalanced tho cause at 80mph I'm getting a little shake.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
