egt temps?? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-02-2013, 01:42 PM Thread Starter
pa05stroker's Avatar
egt temps??
Hey guys I just got an srl tune from Matt and I installed my egt sensor on my edge insight. I was driving up the road and decided to give it some so I put it to the floor. After a couple seconds my edge started beeping and I looked down and my egts were at 1500. That seems high to me. And in my opinion my srl tune is alittle smokey. My buddy has extreme street from innovative and I think his smokes less. Thanks for the help
pa05stroker is offline
post #2 of 20 Old 07-02-2013, 02:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ya 1500 is getting up there. I had a atlas80 tuned ficm and I had just about the same temps.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 20 Old 07-02-2013, 03:53 PM
USAFBowman's Avatar
THAT IS WAY TO HIGH!!!! Have him tweak the tune. Even with an atlas 80 and ecm tune combo the highest i normally ever see is 1250 and thats when hammering on it
USAFBowman is offline
post #4 of 20 Old 07-02-2013, 05:32 PM
scparrish's Avatar
Quoted: 114 Post(s)
Feedback Score: 3 reviews
uh with a factory charger it is not really hard to believe for a hot tune. if you only see 1250 max your running a mild tune or you aren't pushing enough fuel.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Stage 2 Turbo, PHP FICM Tuning, PMF, S&B, Mishimoto rad/ic, 08 axle swap 3.73 gearing
scparrish is offline
post #5 of 20 Old 07-02-2013, 05:44 PM
Snake's Avatar
Quoted: 47 Post(s)
If you were running wide open throttle, then 1400-1500* EGT's are common regardless of what company wrote the tune. If it's a little too smokey for your liking, contact Matt and ask him to pull a little fuel up top. Should bring your EGT's down also.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 20 Old 07-02-2013, 06:13 PM
MWilbur516's Avatar
In all actuality you want to see 1350* at WOT to get a complete fuel burn. I've had several conversations with Eric at Innovative Diesel about this. I see around 1500* (not utilizing my water/meth) on my modified Super Panty Dropper from TSD and my Extreme X from IDP.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #7 of 20 Old 07-03-2013, 01:58 AM Thread Starter
so these temps wont hurt my truck for the occasional WOT run?? would the truck run better if i got him to tweak the tune so that the egts dropped?
post #8 of 20 Old 07-03-2013, 02:03 AM
the chad's Avatar
No as long as it's not sustained, all of my tunes with a stock charger were bt 1400-1500 at wot
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #9 of 20 Old 07-03-2013, 02:47 AM
What is normal cruising EGT's with the srl?
It has been 100+ degrees so keep that in mind.
I've been driving with my tow tune and atlas 40. Cruising on the highway at 75 I'm seeing anywhere fro 740-850ish. Is this normal? It seems in the early morning when its 70ish outside I'm about 100 degree cooler EGT at the same speed.
I ran around with my SRL and atlas 40 for a day and I could hit 1400 degrees by 65mph from a dead stop. Didn't really look at cruising temps. Seems like just "normal" accelerating getting on the highway I would see 1100+
Normal boost numbers are up to 25-26. I have seen up to 28-29lbs.
03 F-250 Lariat SuperCrew FX4
MTW 03 turbo billet wheel
PHP FICM Atlas 40
GearHead SRL
Strokers Unlimited Coated Up-pipes
3.5" dowpipe/4" exhaust
AFE Stage 2 Pro Dry CAI
6.4 Banjo
Blue Spring
EGR Delete
Edge CS
Coolant by-pass filter
Oil by-pass filter
285/75/16 tires on factory rims
03 F-250 Lariat FX4
PHP FICM Atlas 40
GearHead SRL
6.4 Banjo
Blue Spring
EGR Delete
Edge CS
Oil by-pass filter
FATHERFORD is offline
post #10 of 20 Old 07-03-2013, 03:19 PM
Snake's Avatar
Quoted: 47 Post(s)
Outside temps won't have a significant effect on EGT's. Just my opinion, but 850* is a bit high at 75 mph. Not much though. I'm usually around 700* at the same speed (stock injectors, stock turbo) but I wouldn't panic over what you're seeing. Like I said, give Matt a call and let him know what what you're seeing and he can probably adjust your tune to where you want it.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
