a little help with tuning options - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-01-2013, 08:37 PM Thread Starter
mustangmike6996's Avatar
I have a remotely stock 2004 F240 Harley Davidson edition PSD...
Currently have the Edge Juice with Attitude CTS. It has the 6 "power levels" Are those somewhat different then a tune itself?
I am looking to tune the truck, I have heard of a few places that will tune the Edge. Who is the Best?
Also, I have a locked SCT X3 tuner from my 2010 Mustang which I could send back to SCT and have unlocked for 150 or so. Then buy a tune and go that route (it should work with my truck, I havent looked to far into that route)
What do you all recommend?
I was planning on doing an EGR delete and a tune to to get rid of the check engine lamp if it were to come on.
mustangmike6996 is offline
post #2 of 12 Old 07-01-2013, 08:59 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is a copy/paste from PHP.
It is with regret that we are announcing that we will no longer be offering custom tuning for the Edge CS and CTS after December 31, 2012. Since the CS and CTS were released, we have tried to work around some of the limitations of Fusion (Edge internet update software) to help our customers that use our custom tunes. Unfortunately, Fusion was not designed to accommodate custom tuning and so this has been on ongoing struggle for us and our customers. We have asked Edge to modify this software and Edge is willing to have one of their engineers redesign the Fusion software to accommodate our custom tunes. However, after evaluating the size and scope of that project, we have decided that, at this time, we are not in a financial position to make that investment.
http://forum.gopowerhungry.com/gryph...ts-programmer/
Get your SCT unlocked, it will work on the 6.0.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 12 Old 07-03-2013, 11:42 PM Thread Starter
who is a good tune writer for the SCTs?
post #4 of 12 Old 07-04-2013, 02:28 AM
Quoted: 725 Post(s)
Gearhead
Corey@CNCFAB is offline
post #5 of 12 Old 07-04-2013, 03:01 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Unless your SCT has all of the locks used up you should be able to unlock it yourself.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #6 of 12 Old 07-04-2013, 06:25 AM
Powerstroke Techie
Lilpooh's Avatar
Nope, if it's locked, the device needs to be sent back to SCT.
http://www.sctflash.com/support/inde...cleid=24&nav=0
Lilpooh is offline
post #7 of 12 Old 07-04-2013, 09:34 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Rich, this is what I meant to say from someone way smarter than me:
"No you can't use the same unit to run two different trucks. Once you tune the first truck, the SCT locks onto the VIN (marries).
Now if you return the first truck back to stock tune, then you can tune the second truck. BUT then you loose one of the five "unlocks". SCT devices come new with "5 unlocks left", whenever the SCT sees a different VIN it uses up a "unlock". After all 5 unlocks are used up, you will need to send it back to SCT for a unlock fee of $150.
So let's say you tune the first truck, then go back to stock and tune the second truck, you will use up a "unlock". Now you want to tune the first truck again, return the second truck back to stock and tune the first truck, guess what.... You just used up another "unlock". Now you only have "3 unlocks left". Every time the SCT saves a VIN, it uses up a "unlock".
You can tune the first truck as many times as you want and not loose any "unlocks". Because the SCT already has recognized/stores the first trucks VIN."
Shawn
Qholic is offline
post #8 of 12 Old 07-04-2013, 10:37 AM
Powerstroke Techie
Lilpooh's Avatar
LOL!! Sorry Shawn! I misunderstood your first post. I was only on my first cup of coffee! HA!
Lilpooh is offline
post #9 of 12 Old 07-04-2013, 12:31 PM
john galt's Avatar
Quoted: 1094 Post(s)
This is only my opinion and ONLY from research here but I was going to get one tune from tony wildman and a tow and looney from vivian. there are about a million threads here debating tunes and from what i can gather pretty much anybody who writes custom tunes can work wonders with your truck.
I guess grab a cuppa and dive in and see who seems to hit closest to what you want. That is probably my best advice. I just wanted to support wildman and vivian after having spoken briefly with each on this forum.
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #10 of 12 Old 07-04-2013, 12:47 PM
MWilbur516's Avatar
Innovative tunes make awesome power. Vivian's tunes are quick too, Tony's tunes are compareable to Vivian's in the power arena. TSD and Gearhead write AWESOME daily driver tunes, but don't seem to run out on the top like Innovative's Extreme tunes (not as fast on the top as Innovative).
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
