MadMax Turbo Status, Adrian how's it coming - Ford Powerstroke Diesel Forum
post #1 of 33 Old 07-01-2013, 08:21 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Anxious to get one of these bad boys on my Truck....
denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 33 Old 07-01-2013, 11:31 AM
madpowerstroke's Avatar
Still waiting for the compressor wheels to be made, I have found a manufacture that will make them for me with me as sole buyer, so no one else can buy them but me. They will be around the 66mm size induced and should work great for 190 injectors. This turbo will be the MTW offering as a powermax, along with some other tweaks to the turbo it will be a nice addition to the MTW line up. If this turbo does well then some changes to turbo line up will follow.
Might have stage 1, then the MTW powermax(madmax), then stage 3, and stage 4. With stage 4 being a completely new turbo, a combination of stage 4 and 5, not sure since the old manufacturer is dragging the stage 5 way too long.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #3 of 33 Old 07-01-2013, 11:31 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I'm curious to know what all is done to it. The reason I say this is because MTW offers the MTW P-max at like $1900. Just a normal P-max goes for $1100-$1300 depending on who you buy from and then the billet wheel upgrade, another couple hundred. I'm just curious what all is going into the MTW P-max that warrants the cost.
Adrian, don't take as me being an @$$ either, I'm just more inquisitive than anything.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 33 Old 07-01-2013, 11:53 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Shack, it's all on the website (at least it use to be). The Mad Pmax is a Pmax that is modified for the Hybrid billet compressor wheel and has a 13 bladed turbine wheel put into it.
Here ya go.
http://www.madturbowerks.com/index.p...how&Itemid=185
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 33 Old 07-01-2013, 12:24 PM
strokin6L's Avatar
Quoted: 4 Post(s)
So sounds like it'll actually be bigger than the current hybrid with Adrian saying the compressor being 66mm versus the hybrid being 64.7mm. Assuming turbine housings remain the same...the mad ax should flow more and make more power than the current hybrid. Wonder how this turbo would do with my 190/75's compared to my original version hybrid?
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #6 of 33 Old 07-01-2013, 12:34 PM Thread Starter
Quoted: 2 Post(s)
Originally Posted by strokin6L View Post
...the mad max should flow more and make more power than the current hybrid. Wonder how this turbo would do with my 190/75's compared to my original version hybrid?
Should be even cleaner cooler and more MAD!!!
I'm in the same ball park albeit i run the 175-75's my bet is once this thing is out and results come back there will be a large # of Hybrid owners crawling back under the hood.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #7 of 33 Old 07-01-2013, 01:04 PM
Quoted: 10 Post(s)
Denny
If I crawl back under the hood, it will be to install the turbo I wanted from the get go...lol..
Shack
post #8 of 33 Old 07-01-2013, 01:16 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Denny
I already have a stage 3 coming...but I'm very anxious to hear results from someone who has a hybrid and switches to this turbo.
post #9 of 33 Old 07-01-2013, 02:24 PM
BACKYARDIGAN
Quoted: 4 Post(s)
I'll be switching to this turbo to run one of the first prototypes and I will be coming from the latest Hybrid. So I'll be able to see what's what.
Nate
post #10 of 33 Old 07-01-2013, 02:37 PM Thread Starter
Quoted: 2 Post(s)
I'll take that old ragged hybrid off your hands and someone can have my Gen 1 Hybrid.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
