for those with 175 cc injectors..... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-30-2013, 10:51 AM Thread Starter
Quoted: 9 Post(s)
I'm kind of new to the nomenclature of the aftermarket HEUI injectors, can someone fill me in? they are 175cc with stock nozzles
Might get a deal on them. I'm wondering how they affected your mileage and such. I was going to keep it stock besides programmer and exhaust, but might do the upgrades.
Which turbo can I use best for these? anyway to keep stock spool up??
I only have the blue spring and 6.4 banjo bolts. Will this be sufficient for the injectors??
What kind of power can i expect?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 8 Old 06-30-2013, 12:19 PM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
Basically, nomenclature wise, its the cc injected for 1000 cycles / nozzle size. (basis, stock is about 135cc - at best).
Stock nozzles are going to be your limiting factor on power. They only flow so much fuel in an injector cycle running over 3k rpm, so in the higher RPM band you will not see much HP gains.
A programmer will be a must, as will be the exhaust system (at least a 4" setup). The turbo will be the key in making the most out of those injectors. (Check the performance thread in sig.)
As for the fuel system, you may need a regulated return and a newer pump configuration. Really won't know how far you need to take it, until you get the pressure numbers under WOT.
Power wise, again check the performance thread. Under a stock turbo upper 400s, with a newer turbo 500+
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 8 Old 06-30-2013, 02:54 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I currently am running 175/75's with a stock turbo, stock fuel system, FICM tuning and ECM tuning. The truck is a beats and I avg 14.5-15.6 mpg's mixed driving. I have an MTW Hybrid on the reloading bench awaiting installation and my regulated return is awaiting installation as well. My suggestion is this, 175/30's, a billet wheel for your stock turbo and a regulated return. You can also run a sump to your factory pump so it's not pulling double duty. You won't be disappointed.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 8 Old 06-30-2013, 03:46 PM
colonel angus's Avatar
Quoted: 2 Post(s)
You won't see much improvement with stock nozzles but you can send them off and get 30's (my recommendation) but it will be pricey.
You'll want the new MTW PowerMax or the hybrid Minimum if you keep stock Nozz's.
It will be fun to drive but be warned it's the start of a lot of programming and possibly wrenching on it unless you get a perfect Turbo from the beginning.... So if it's your only means of transportation or you can't be without it I wouldn't go down this route, it can get bumpy.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 8 Old 06-30-2013, 05:02 PM
Quoted: 10 Post(s)
I would stick with the MTW Stage 1 as that one doesn't necessarily require turbo tuning...it helps be it has great behavioral tendencies without tuning.
Shack
post #6 of 8 Old 06-30-2013, 05:16 PM
pizza pig's Avatar
Denny
you will notice significant performance going from stock injectors to larger barrel with stock nozzles if built and tuned properly. Can also be very reliable if done right.
pizza pig is offline
post #7 of 8 Old 06-30-2013, 05:46 PM
peixinho's Avatar
Quoted: 228 Post(s)
I would venture to say that whoever is telling you that 175cc/stock nozzles will not flow much over stock, or that you will not notice much gain over 135cc injectors has not run them before... either that or warren diesel sent me the wrong injectors.
I have had 4 6.0 trucks. All of them have had stock injectors pushed to the max through all the small upgrades.
I can tell a HUGE DIFFERENCE with my 175cc/stock with stock nozzles. My MTW stage 1 even has a hard time cleaning up all the smoke and it looks like a freight train going down the street at WOT on a race tune. My stock injectors would clean up to a faint haze (much less fuel on stock injectors). This is not a good thing... but my EGTs can get up to 1800 on a hard full fuel tune. I only say that because my truck is running on the high side of the amount of fuel. I definitely could use a bigger turbo to help clean up all the smoke and keep the egts down.
I do agree the at very high rpms (like 3500+) you can tell that the stock nozzles are not keeping up with the fuel demand
Also what is a good deal... I know warren sells them for like 600-700 dollars with an awesome warranty
just my .02
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 8 Old 06-30-2013, 06:19 PM
Quoted: 2 Post(s)
I wasn't insinuating you wouldn't see much improvement, rather it's a combination of other things required to make it achieve the most from them.
That's a better way of putting it, and it's not a sure thing this tune and that turbo will respond the same way on your truck, especially if it's an 05.
We got the special trucks.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
